![]() | Home > Technical > Wondering at 50 plus mph |
Mitchsafety Member Since: 26 Jan 2013 Location: Suffolk Posts: 9 ![]() ![]() ![]() |
Hi all sport owners, I have an issue with my car when driving along the road any slight change in canvor results in the car going all over the place, I have had the 4 wheel alignment reset to factory settings , this did improve it slightly.
The near side lane up the M6 probably had groves in it caused by HGV's all running in the same tracks, very common on a lot of motorways especially on uphill sections. |
^^^^ I'd be tempted to agree with Ady's opinion above.
Good Morning Guys,
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4424 ![]() ![]() ![]() |
Does the suspension clonk, or knock at all?
Hi , Have been told i need all the bushes replaced , as this is causing the wondering and the two front tyres are now needing replacement after just over 3000 miles, so much for getting a newer Range Rover .
Hi Guys , just a quick up date and god do i feel silly |
I spent £60k on the car, first thing i check - fluids, pressures and nut tightness
Yep - within the first day or so. update the cars specs (with the other cars we have) and check the fluids etc. I check all the cars fluids/pressures regularly - its a good habit to get into Mike 2014 Facelift Discovery |
I agree, prevention is better than a cure, are you a transport manager by anychance in your spare time |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
I don't agree with mse on very much but i do on this topic. I check whatever can be checked 2 weekly on both vehicles. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
I've not checked a tyre pressure or fluid level on mine since I got it 2 years ago! I bet i'm not in the minority as well. |
BKHK and i might be in the minority - a first for me, but it looks like twice for him |
