Home > In Car Electronics > Relay clicking noise? |
If the guys fitting the tints spent a few hours with the doors opening and closing then the interior lights would have been on quite a lot of the time and if they were playing the radio at the same time the battery may have been drained. Have you bought yourself a CTEK battery charger yet? I bought a MXS 5.0 last year and it is really great. Put the battery on charge and see if everything is resolved. If it happens again you might need to check the battery drain - all you need is a multimeter (Screwfix sell a good value one ) 2008 MY Java Black TDV8 HSE
Wed Mar 13 2013 6:31pm |
57TDV8 Member Since: 16 Jan 2013 Location: Cirencester Posts: 113 |
Hi Paddi, the guy only spent a couple of hours, but ran the car abit in idle also. I've had 1 short run in 2weeks and the fact the ACC warning switch (next to door lock/unlock) comes on points to battery. Will have a look at one of those chargers tomorrow, nice 200 mile run on Saturday should help! 2010 TDV8... |
Wed Mar 13 2013 6:57pm |
Went out this morning & got a charger, turned the passenger airbag off, but the light illuminates all the time & the ACC triangle button flashes when ignition on stage II. Got the low power warning when turning the stereo above 20 (test ) so looks like it's the battery giving spurios issues.
Thu Mar 14 2013 10:17am |
Thu Mar 14 2013 12:00pm |
Hi Paddi,
Thu Mar 14 2013 12:08pm |
It looks as if the voltages you are seeing simply reflect the voltage being used by the charger at different stages of the cycle. i.e. they only indirectly represent the stage of charge of the battery.
Thu Mar 14 2013 12:54pm |
Cheers Paddi,
Thu Mar 14 2013 1:03pm |
All fixed now with a good charge, no airbag or ACC button errors 2010 TDV8... |
Thu Mar 14 2013 10:21pm |
as kav would say -'another small but significant victory for the DIY brigade' 2008 MY Java Black TDV8 HSE
Fri Mar 15 2013 10:46am |
