![]() | Home > Maintenance & Modifications > What is the truth about software updates? |
Mine is a 2012 model SDV6 and i had to tell my dealer that my motor required a gearbox update (i found out the info elsewhere) when my dealer checked they said that there is two software updates required for my vehicle, one for the gearbox/transmission and one for the gear selector, so both now upto date, but i have to ask myself the question, if i hadn't mentioned it, would they have done it??? That i guess i will never know. Has it made any difference ? If anything it takes longer to select the gear ie if i'm going from R to D or the other way around |
uffington15 Member Since: 25 Apr 2012 Location: Alhama de Murcia Posts: 25 ![]() ![]() |
was having a lot of trouble with my 2006 TDV6 and the garage I was using took it to a LR main dealer. They had it for 3 days and carried a lot of updates, the car had not been updated since 2007, Believe we got a good rate as this is Spain and if you speak the lingo you get a better deal. Car has been good as gold and we had a trouble free trip back to UK & back. In my opinion they are worth doing Silver 2006 2.7 tdv6 |
57TDV8 Member Since: 16 Jan 2013 Location: Cirencester Posts: 113 ![]() ![]() |
I asked the Head of Service at Guava and he said all SW is not updated automatically, only if there is an issue or fault code relating to something that has new SW. He said its a bit of an urban myth that the SW should/is updated very time it goes in to a dealership... 2010 TDV8... |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
Looking at the ZF troubleshooting guide, it's absolutely essential that the gearbox adaptations are reset before any software flashing is done. And this isn't done by hard resetting the vehicle - it has to be done through a diagnostic device.
There is a difference between updates to fix a problem and service improvement updates.
SturgeRRS Member Since: 05 Jan 2013 Location: Surrey Posts: 96 ![]() ![]() ![]() |
I have always been lead to believe that if its controlling hardware then it needs firmware updates.... |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
Is your gear lever tight to move? It could only be a �10 fix... http://disco3.co.uk/forum/topic31656.html ![]() ![]() |
Thanks DM, Wouldn't say the gear lever is tight but I noted your 'how to' (ZF guide also mentions the pivot issue) and as soon as the weather is a bit warmer I'm planning to do that job anyway on the basis that preventative maintenance is always a good idea. Thanks to eveyone else who has commented too. It seem that the LR Dealers should really check at services that the software is up to date in the same way that they should also check for TSBs but I suspect they don't bother particularly if the car is a few years old. I agree that the 'software' might be more accurately described as 'firmware' but as all of the LR and ZF literature use the software nomenclature let's keep it simple shall we? The software could be up to date but if there is a fault then 'reflashing' it (which really means re-installing it) may solve the problem - presumably because like any software it is possible that part of it has become corrupted. As an example you may have noted that if you report a problem to a software vendor they often suggest re-installation as the first option and it usually works. (Does with my iDrive cloud back-up system anyway!) Had a chat yesterday with my trusted Indie LR specialist and asked if they could clear the adaptations. Got an enthusiastic and helpful response as usual. Apparently they have just bought a new diagnostics computer system but haven't used it yet so they are going to have a look and see if it gives them access to the latest engine and gearbox updates and get back to me. That might sound a bit worrying but one of the lads who usually looks after my car is pretty experienced with their previous Auto Logic system and an ex LR technician and takes a pride in his work so I don't think they will tackle the job unless they are sure how to do it properly. So watch this space. 2008 MY Java Black TDV8 HSE ![]() |
