![]() | Home > Technical > Windscreen washer |
From TOPIx:
sagalout Member Since: 26 Feb 2013 Location: Harrogate Posts: 128 ![]() |
Thanks for that - does that mean the heating element comes from fuse 12 and the actual motor from fuse 38? Are heated jets standard? Not sure which one I should be looking at |
Heated jets: Not sure they are standard, do you have the 'Cold Pack'? CP was standard on UK HSE's I think, but I see you have an SE, maybe it was added as an option ?
Thanks again - I'll pop into halfrauds on the way home and get a replacement. |
On my MY12, the fuses are the pony little ones, but not sure if MY11 is the same, best check before you buy the wrong size. I'm sure someone will comment for you |
