Home > Technical > How to change KMH dial to MPH dial on insturment cluster |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 |
Don't know if you have the same in pre 2010 model , but in mine you can change the digital speedo reading to kph and litres/100km by going into the settings on the centre display. If you are taking it out of the uk again soon, then it might not be worth choping and changing the speedometer!
Tue Mar 05 2013 6:16pm |
Just searched and came up with this, courtesy of bobby!
Tue Mar 05 2013 6:22pm |
Tue Mar 05 2013 7:20pm |
RRSamuel Member Since: 30 Jan 2013 Location: UK Posts: 12 |
Thanks! I also just found that. I might try to do it first with out removing the steering wheel, if there is enough space.
Wed Mar 06 2013 8:37pm |
Help needed!
Fri Mar 08 2013 9:55pm |
