Home > Faults & Fixes > Auto gearbox faulted and display F on instrument
consort
2006 Range Rover Sport Supercharged Java Black
My auto box on my 2006 supercharged faulted and gave a warning of limited gear selection, (or similar to that) it drove fine and all gears went in perfectly, but I could not engage off road etc. or manual sport mode. I stopped the car and restarted it, all fine. Any clues please?
Post #374823 Tue Feb 26 2013 1:13pm
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Happened to me 3 weeks ago.
No problems since.
Intermittent fault.
An intermittent fault, often called simply an "intermittent", is a malfunction of a device or system that occurs at intervals, usually irregular, in a device or system that functions normally at other times. Intermittent faults are common to all branches of technology, including computer software. An intermittent fault is caused by several contributing factors, some of which may be effectively random, which occur simultaneously. The more complex the system or mechanism involved, the greater the likelihood of an intermittent fault. SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #374835 Tue Feb 26 2013 4:20pm
consort
Yes thanks
I thought that might be the case.
What a great car though!!
Post #374913 Tue Feb 26 2013 11:25pm
