Home > General > Towing Electrics
RobertNaylor
2012 Range Rover Sport SDV6 HSE Luxury Orkney Grey
Towing Electrics
Hi everybody, I have moved over from the Disco site, finally took the plunge (today) and upgraded to a RRS, pick it up next week. Been using Disco since the early 90's, my last one being a Disco 4 XS 2011. Know the proud owner of a 2012 HSE Lux in Orkney Grey. Always got great help on the Disco site and looking forward to more of the same now I have a posher car.
I have one quick question if anybody can help, I normally take my towing gear from car to car, can see I think that the tow bar will fit but not sure about the electrics, any advise greatly welcome. Regard Rob
Post #374605 Sun Feb 24 2013 11:42pm
Morpheus-RRS
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Hi Rob and welcome to the forum, for sure the tow bar will fit but not sure of the electrics. i'm sure someone will be along soon with some help. Thumbs Up Dave.
MY12, SDV6, HSE Orkney Grey, Cream leather with contrast stitching, Side steps, Tow bar and electrics, privacy glass.
Post #374615 Mon Feb 25 2013 8:12am
simple1
Same loom and layout so theory says it should be doable. If it were me I would have the swan neck and get yourself new electrics. The sockets might be protected but usually go green with time so opertunity to get some new shiney bits. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #374619 Mon Feb 25 2013 8:55am
1014rk
I agree with simple1 but , I think the wiring loom changes between 2011 &2012. If you look on Duckworth (site sponsor) site, they will supply a landrover part at a reasonable price. This is an easy DIY job, the instructions that come with the new wiring are hard to follow, top tip the bumper cover has to come off. This is a simple job, but I missed this picture and could not work out where the extra wire had to go Whistle but a quick call to Duckworth cleared it up Thumbs Up
RK MY 2014 3.0 SDV6 HSE Dynamic
Causeway Gray
My2011 3.0 TDV6 HSE Luxury Nara Bronze (gone)
Post #374649 Mon Feb 25 2013 11:38am
flack
Very easy DIY job the only awkward bit is getting the loom around the chassis..
Flack Thumbs Up
Post #374651 Mon Feb 25 2013 12:01pm
Endjin
Scotland
Hi Rob and welcome to the forum.
Funnily enough, I'm just about to move in the opposite direction!
After 2 RRS's over 6 years. I have decided on a change and have bought
an Disco HSE Lux which I get on 1st March. I am keeping the removable
tow bar but am definately having new electrics fitted to the Disco. Would
not want to transfer 3 year old electrics over as the risk of faults would
not be worth the saving. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #374738 Mon Feb 25 2013 7:31pm
mse
You have to change the electrics anyway...they changed almost every year since mid 10.
Fitting is easy, you can access everything with the bumper off...plugs are on top Mike
2014 Facelift Discovery
Post #374790 Tue Feb 26 2013 12:16am
RobertNaylor
Hi Guys, thanks for all the info. Seems a simple job except for the removal of the bumber, and advice on this would be welcome, are there any photos or diagrams to explain how to do this, Cheers Rob
Post #374815 Tue Feb 26 2013 10:29am
1014rk
The removal of the bumper is easy, it shows the location of the screws in your handbook. It is only the size, and somewhere to put it safe that is a problem.
Do not be put off.
The hardest part for me was removing the rear lights, they are held in by two screws, but the seal takes a good hold. I think the instructions say remove both, but I think you can manage with only passenger side removed.
Causeway Gray
Post #374819 Tue Feb 26 2013 11:16am
mse
You need to fully remove the bumper to fit the electrics.
Removing the bumper is a straight forward job and documented on here:
- Remove the lights (2 screws for each unit - but a rag on the top of the bumper to protect it and pull)
- Remove the Grey kick plate and pop out the plastic rivets
- Undo 3 screws at each wheel (rear)
- Undo 4 screws along the bottom
- Pop the bumper sides (clips behind) off from the wing
- Pop the last remaining plastic lugs and walk backwards (easier with 2 people) job done Mike
Post #374831 Tue Feb 26 2013 1:53pm
RobertNaylor
Thanks for all the help, decided to have a go. Contacted a seller on Ebay who turned out to be Beadles of Sidcup and the guy there advised the following-
"Hi, these can be fitted yourself as they simply just plug into the loom and
mount under the bumper but your vehicle will have to go to a Land Rover main
dealer to have these configured to the vehicle otherwise they will not work."
I replied-
"Hi, thanks for the reply. Will they completely not work or just the
additional features (parking sensors etc) that will not work."
He then replied-
"Hi Rob, no i'm afraid they won't work until they are configured to the vehicle."
This was not the impression I get from all of the other posts and your good advise. Is he correct?
Thanks
Rob
Post #375057 Wed Feb 27 2013 11:07pm
mse
My 2011 worked without activation - i activated my 13 before i fitted it Mike
Post #375060 Wed Feb 27 2013 11:29pm
Endjin
Scotland
MSE, How did you activate it? Or did you have to get dealer or specialist to do it? 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Post #375151 Thu Feb 28 2013 6:06pm
simple1
Have fitted eBay system to disco 4. Only thing that didn't work properly was parking sensors. On my car they switch off when trailer is plugged in. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #375169 Thu Feb 28 2013 7:34pm
mse
neither...I have access to the kit Thumbs Up
You wont have tow stability assist either...but the lights will still work Mike
Post #375170 Thu Feb 28 2013 7:48pm
