![]() | Home > Technical > Electronic trouble with my RRS |
Paolo, how old is your RRS ? Is it one of the early ones as they seem to have had more than their fair share of electronics problems, most of which seem to be false alarms. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
wasnt it starting with some Batterie probs -cable on the carroserie ?
RRS67 Member Since: 01 Jun 2006 Location: Italy Posts: 9 ![]() ![]() ![]() |
It has only three months life, and it has never had problems (battery or other) before.... |
Pelyma Member Since: 28 Sep 2005 Location: Sussex Posts: 1497 ![]() ![]() |
Low battery throws up all sorts of weird and wonderful errors, but surely they would have checked that? |
It seems like there's an issue with the pressure sensor which gives a reading of 1800 bar. Anyway it happened with the engine running and while driving the car too. Ciao... |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Paolo, I hope your issues have been taken care of by now, but I found this Tech Bulletin for RRS that may possibly apply to your problem:
thanks umbertob - that was the thing i talked about...
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
I had the very same problems last year - really annoying - turned out to be BATTERY problem and connections - so had new battery and replaced all connectors etc - now all OK |
I thank you all for your suggestions. Now I finally can tell you the problem which seems to be solved.
Andy Member Since: 15 Oct 2005 Location: Shropshire Posts: 1369 ![]() ![]() |
Ok, I've got to admit at reading the thread title wrong just then |
