Home > General > Suspension fault |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2794 |
You may be unlucky and have 2 different problems occurring at the same time - what do you mean by suspension playing up? 16MY Estoril Blue SVR.............
Mon Feb 18 2013 8:54pm |
Sunnyv Member Since: 18 Feb 2013 Location: Ilford Essex Posts: 10 |
Thanks peachy for responding so quick. Poor to having the battery problems sorted I used to get "special programmes off" and "normal suspension hight only" with the orange wobbly indicator. She suspension would lower but then raise to normal hight immediately. just wondering where I go from here, been advised I need a new suspension control unit. |
Mon Feb 18 2013 9:01pm |
V8SC Member Since: 29 Oct 2011 Location: Hampshire Posts: 145 |
Had exactly the same with mine. New air suspension compressor sorted it good as new Carl |
Mon Feb 18 2013 9:04pm |
Thanks Carl will get it checked out. Can the unit be reconditioned? |
Mon Feb 18 2013 9:09pm |
I can only advise from my own experiences - the suspension Compressor is located in front of the n/s rear wheel - it becomes noisy when its due to fail - mine had been refurbed ( in a fashion ) & started to play up almost straight away after I had purchased the car. It was showing the same faults as yours - it was replaced & it's been great since. The lads on here are great - some are close to genius when it comes to solving problems so stick with it !! 16MY Estoril Blue SVR.............
Mon Feb 18 2013 9:13pm |
....not sure if it can be reconditioned or not but in any event you might find a new one more cost effective anyway. There is a relay that needs to be replaced as well.
Mon Feb 18 2013 9:18pm |
Thanks Cartland peachy for your advice, greatly appreciated. I'll let you know what happens.
Mon Feb 18 2013 9:24pm |
That's what everybody says 16MY Estoril Blue SVR.............
Mon Feb 18 2013 9:25pm |
Hello all, it's me again. I am about to buy a new air suspension control module and wanted to know how and where I would get the right part number. It's a 2005 2.7tdi has, BMW engine. |
Thu Feb 21 2013 6:33am |
Gary Member Since: 22 Jun 2006 Location: Essex Posts: 268 |
Sunnyv, definately not BMW Engine, designed by Ford/Peugeot with help from JLR built by Ford at Dagenham |
Thu Feb 21 2013 7:25am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
It's the Lion V6. Ford / PSA as mentioned.
Thu Feb 21 2013 9:52am |
RRS-Spy Member Since: 01 Nov 2011 Location: London Posts: 169 |
Does anyone know if the compressor is covered by the LR warranty ? Proud owner of a 2008 TDV8 HSE.....and an Audi A3 2.0T DSG Cab and a Porsche 911 Turbo (Mercedes W208 320 CLK and Mercedes W124 E220 Estate now gone) |
Thu Feb 21 2013 4:43pm |
