Home > Maintenance & Modifications > dpf filters |
Its called evolution. |
Wed Feb 13 2013 9:31pm |
Lets not get on to climate change because i think you may have an appreciation of my view exactly opposite to my actual view
Wed Feb 13 2013 11:13pm |
So do farmers use different oil to us? Mine is using whatever they put in at the factory, so i can't see that being the wrong oil. My dpf light came on at around 6500 miles on the clock of which only about 2500 are motorway miles, id be surprised if farmers do 2500 miles in a year in their 4x4's, they are usually in their tractors. |
Thu Feb 14 2013 7:45am |
in my 11MY i did a month of 5 mile journeys in it every day...no DPF light on. Mike
Thu Feb 14 2013 4:26pm |
- mse perhaps you'll explain to me why a change in engine oil will change to build up of soot in the DPF which is from burnt fuel? |
Thu Feb 14 2013 4:51pm |
Read the post above from oldcro he explains it. he actually mentioned it It is true (read your manual) - part of the reason for using the correct spec oil is about SAPs and the impact of the DPF. Its common (because the correct spec isnt commonly available) to use the wrong oil...in fact is the difference between A and B Incidentally - i assume you know how a DPF works - i though you were mechanically minded Because i appreciate the sarcastic reply ive just made a little more thought through: Ash deposit increases exhaust back pressure, which increase fuel consumption & loss of engine power & deposit shortens the life of a dpf. It comes mainly from engine oil which is why low ash oil must be used! Gone are the day's of one size fit's all & viscosity is not a specification! Mike 2014 Facelift Discovery |
Thu Feb 14 2013 4:57pm |
this may also help:
Thu Feb 14 2013 5:04pm |
Tbh, i think it would take more than a months worth of 5 mile journeys to bring the light on, doesn't it clean itself out every 2-3000 miles ? I know when mine came on i hadn't been on a long run for quite a while. |
Fri Feb 15 2013 7:40am |
Ref the articles. quoted above ..
Fri Feb 15 2013 3:20pm |
I think you are missing the point - the OIL spec did change in 11 and you struggle to buy it, but you can buy one that is almost identical but the long code has a B at the end - Land Rover put the correct spec in, i hope the dealers do (although i know of one that doesnt) but any other garage or top up...probably doesnt Mike 2014 Facelift Discovery |
Fri Feb 15 2013 5:01pm |
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 |
If your Range Rover has a DPF fitted your handbook recommends the following engine oil;
Fri Feb 15 2013 6:50pm |
Double post again. |
