Home > Maintenance & Modifications > Sidesteps and Media Headrests from Ebay...Buy or stay clear?
Page 2 of 3 <123>
jitzz
WOW...Karan they look great !
That's convinced me to get them, will be on eBay as soon as I get off here.
thanks for the pictures - the fit looks excellent they look factory, I really like the fact they are HD and they zip up out of sight
Were they easy to fit?? ....I'm not too bad with these kind of jobs so would like to do it myself, unless it requires a bit more expertise
Thanks again for the insight
Jitzz
Post #372405 Wed Feb 06 2013 1:41am
karan538
2008 Range Rover Sport TDV6 HSE Santorini Black
You will need to open the back of the seat to run the power cable. You can either hardwire it or use the cigarette socket to run them. They provide both the adapters. Dont buy off ebay, buy it off there website. You also need to choose the correct size of the poles for the headrest that will fit your range rover. Add them on skype or send them an email and ask for the sizes.
You simply cant go wrong with this purchase, 240pounds for 2 headrests with screens fitted already. + much better specifications and touch screen then other companies asking for a ridiculous 800pounds for junk.
Post #372406 Wed Feb 06 2013 1:45am
airwolf222helicopters
dvd
jitzz
what did you buy in the end ?
im thinking of the hd906 t as they are 250mm wide so hopefully fit
let me know what you bought
dave
Post #372489 Wed Feb 06 2013 10:43pm
jitzz
Hi dave
I think I'm gonna go for the HD908 with touchscreen and fancy remotes, Very Happy
not ordered yet but it's the toss up against the hd906 t which you mention - will get them them ordered tomorrow once I've done a final comparison and got a response from them in terms of the correct pole sizes for the RRS
I'll let u know when I've done the deed !!! Thumbs Up
Thanks
Jitzz
Post #372493 Thu Feb 07 2013 12:02am
DVD
Hi jitzz
Yeah nice screens but I think the 906 look better personally and un clip for security say if u go on hols ?
Ok I emailed them and below is there very cautious of there commitment to say if
Reply:
Thanks for your interest in our items. They are universal and can fit most cars, very easy to install, the poles are adjustable, and there are 10mm and 12mm poles coming with the headrests. If the 10mm and 12mm poles cannot fit your car, you can buy the 14mm poles from us. Please note that the inner width between the 2 poles is from 120mm to 190mm, you also need to compare this size with your original headrests. Should you have any question, just feel free to contact us.
If you have any other questions, please feel free to contact us.
Best regards,
XTRONS Support
www.xtrons.com
I'm going to measure the poles tonight
And then decide
Post #372503 Thu Feb 07 2013 9:01am
jitzz
Hi Dave,
Good call on the pole size check before you order them....could save a lot of headache. I think these guys have a uk distribution centre so shouldn't be too bad.
The last deal I saw included the remotes, games and free set of headphones, so well worth it in my opinion. I suppose the comment from them looks to cover all eventualities so , I got the same note too..
I'll keep you posted
Jitzz
Post #372548 Thu Feb 07 2013 1:32pm
Hi jitzz
Measured the poles with micrometer and they are 11.99 mm = 12 mm will do
Pole distance from centres are 150.1mm so they adjust to 190mm so ok on that front
Will order mine tonight
Have you made up your mind on which ones ???
Dave
Post #372617 Thu Feb 07 2013 6:16pm
jitzz
Hi dave
You're a star for doing all the hard work to get things measured ....I'm going to order mine too Very Happy
I'm going for the black headrest HD 908 with the free headphones they are a bit more, but I like the zip cover which hides the screen when not in use ...are you still going for the 906's
Will let you know when I get them delivered, should be straightforward to fit so will look to get them in ASAP
Thanks again
Jitzz
Post #372671 Fri Feb 08 2013 12:36am
I'm now slowly looking at 908 's but the headphones don't come with them
Have you ordered them?
Dave
Post #372829 Sat Feb 09 2013 12:48pm
karan538
Skype the supplier and ask for the headphones separately if they don't originally come with it. There might be a separate cost
Post #372835 Sat Feb 09 2013 3:57pm
karan538
Post #372836 Sat Feb 09 2013 3:58pm
jitzz
Hi dave
I've ordered the 908's from a company called caraudiopoint, search them on the net cos they do the units with two IR headphones and all the accessories for £259
Seemed ok to to me, rang them first and spoke to a nice chap who was really helpful
Cant wait til they arrive Smile
Jitzz
Post #372989 Sun Feb 10 2013 11:50pm
dvd
i have ordered them today 908 's
let me know when you have them and also a pic Thumbs Up
Post #373261 Tue Feb 12 2013 10:10pm
Andyp247
Hi all,
I ordered the HD908 in Black from ebay as they come with 2x headphones and 2 controllers, they only took 2 days for delivery
http://www.ebay.co.uk/itm/190717305206?ssP...1439.l2649
But I am having problems opening the back of the seat so that I can hardwire them in. I managed to fed both wires inside the seat but cannot get the wires to come out of the bottom of the seat Big Cry
I have tried using the advice from this post
http://www.rrsport.co.uk/gallery/albums/us...0Cover.pdf
but still cannot get the bottom apart Big Cry
does anyone have a "how to" with photos Question or a easy way to open up the bottom of the seat back
Great site
Andy
Post #374367 Fri Feb 22 2013 4:26pm
this is a simple thing to do
at bottom of seat ( you want to adjust seat up to max and top half fully forward )
there is two C shaped trims one inside the other (like when you put ur fingers togeter when cold ) = {}
slowly and with pressure start at one end of them push bottom trim up and with force top trim down and slowly pull apart
then bingo hand up wizards sleeve pull cables down and do reverse to put back together 5 min job !!
908's are the nuts i have too but im getting poles made to sit headrest forward more Thumbs Up
Post #374413 Fri Feb 22 2013 10:59pm
Page 2 of 3 <123>
