Home > General > Vibration At Speed
Cheney Jawa
Vibration At Speed
I'm getting a very subtle vibration down the motorway which is very recognisable at about 90mph (yes i know it's above the speed limit blah de blah de blah Very Happy )
It's not a constant vibration more 'rotational' as in 'on off on off on off', it's enough to make the headrests visibly vibrate in the back of the car Shocked
Has anyone else experienced this?, or is it something else i should put up & shut up? Laughing Laughing Laughing Owner of MY13 RRS Red Edition, Santorini Black, Ebony with Lunar, Privacy Glass & Exterior Design Pack
Post #371100 Sun Jan 27 2013 4:05pm
Try balancing the wheels first and see how that goes, but check you haven't picked up and weights made of mud first or atleast road grim
Post #371102 Sun Jan 27 2013 5:02pm
braveheart20
Scotland 2012 Range Rover Sport 3.0 TDV6 HSE Fuji White
Vibration
Hello, I have a similar problem with my 2012 rrs.
Wheels balanced ? Haven't checked this out yet but nothing should have changed.
Should I go to the dealer with this issues?
Brave My 2012 RR SPORT in white
My 2010 SLK AMG in white
My 2012 Quadzilla rs8 In white
My 2012 Mini countryman in white
Post #371114 Sun Jan 27 2013 6:04pm
mse
Re: Vibration At Speed
We had this with a freelander once. Not that it is necessary the issue you have though
Do you want to know what the solution was...a complete set of tyres, fully balanced and then again a 4 wheel alignment.
4 wheel alignment was pointless without the new tyres as the damage was done, again the new tyres were properly balanced.
run your hand along the surface an see if they are rough in reverse, this may indicate something Mike
2014 Facelift Discovery
Post #371122 Sun Jan 27 2013 6:46pm
Jacobite
Scotland
I bought my RRS last week & found the same whilst driving home up the Motorways. A vibration coming through
the steering column when driving over 60mph. I went to the local garage yesterday & they balanced my front wheels. So far so good..Worth a shot Thumbs Up
Post #371326 Tue Jan 29 2013 7:32am
overfinchred
I have the same issue and have new Overfinch alloys and tyres
All 4 have been re-balanced and 4 wheel alignment
Mine happens at about 65-70 and then goes then comes back when braking through the same speed
Now getting it booked into an independant to see if these are suspension issues? “One good thing about music, when it hits you, you feel no pain.”
Current RRS Overfinch TDV8, Nissan Skyline R34 GTT, 1958 VW Splitscreen camper, 1961 VW Splitscreen Double cab pickup( now gone), Fiat 500
Gone -BMW X5 and X6, Jaguar XF, Chrysler 300c, Nissan Figaro, Nisan 350z,BMW 3 series, Merc 220d, various Fords, Mini Cooper, 3 old shape mini's, Ford Capri
Post #371393 Tue Jan 29 2013 2:22pm
drdelrrs
Sometimes these vibrations that are road speed rather than engine speed can be driveshaft related.
Obviously get the wheel balanced etc firstt but then check the centre propshaft joint and then the other driveshaft.
Post #371403 Tue Jan 29 2013 2:45pm
BKHK
When I had a similar problem, it turned out to be the rear differential which was replaced by LR. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #371406 Tue Jan 29 2013 3:07pm
braveheart20
Further update,
Car was in at Pentland landrover today,
They have supposedly repaired the vibration issues with the car.
some issue with the rear breaks? and they balanced the rear wheels after a few attempts, they informed me. they had to burst the bead on the rim, where they removed approx. 1 ltr of water.
now i am being charged for the cost of balancing of the rear tyres.
I picked this car up from a landrover specialist. the specialist had purchased the car from Duckworths landrover. the car was pre registered and had delivery miles only.
Pentland are suggesting the tyre has been changed at some point. i dispute this as we have had the car from new,
has anyone every come across this before i have had many new cars and this is a first for me.
I assume landrover should be able to trace the tyres back to a batch number to prove that the tyre has never been changed out.
I just feel its a little bit of a story.
Incidentally the vibration on the car was that bad that we could not drive above 60 mph. and a heat should had vibrated loose and was hanging down.
the dealer said he has witnessed these heat shields coming loose on discovery models.
i fear this is my dreaded problems started with my range rover sport.
will keep you posted.
Kind regards
Tom M My 2012 RR SPORT in white
Post #372211 Mon Feb 04 2013 6:47pm
Silvermercf1
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
VIBRATION AT HIGH SPEED
RRS 2013 BLACK EDITION. Had the car from new, after a few months started to get vibration in the car. Head rests visually vibrating ect at about 88 - 90 mph. Eventually found we could not balance one of the rear tires. Found about 1 pint of water in the Tyre. This happened yet again some months later. The car is now 2.5 years old and the same problem is back again. It has been suggested that the water is a build up of condensation. A possible solution is to re inflate with nitrogen and re balance after removing the water. This is my next course of action. The car is still under warranty. Reported this problem on a couple of occasions to RR dealer. They say no one has ever reported this problem before. It must have happened when I put air in the Tyre. incidentally I have never put air in this cars tires, the pressures have always remaineded okay.
Post #491824 Sat Mar 26 2016 5:28pm
DrRob
Water in Pirellis has been reported previously. Do a search on here Thumbs Up Visitor from fullfatrr.com
Post #491825 Sat Mar 26 2016 5:39pm
Silvermercf1
Thanks DrRob
Is this a problem with Pirellis Tyre or a problem with RR? Do you know a link where I can get further information?
Post #491828 Sat Mar 26 2016 6:37pm
Garage Door Medic
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Mine was in 2 weeks ago, water in the tyres, took then 2 days to find the fault, they told me Pirelli have now a special sealing paste to stop this happening, took me two hours to remove the black gunk for my rims, they didn't charge me, but said it isn't covered under warranty. But as a jesturevof goodwill they will do it this time. These are the original tyres P Zero MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Ivory Premium Leather
Side steps
Disklok !!!!!!!
Mud Flaps
Spare wheel protector
Post #491943 Sun Mar 27 2016 10:06pm
