Home > Maintenance & Modifications > Can i mount resistors on OEM LED rear lights..... |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 |
As long as you know how to do it then yes you can. 2014 L405 SDV8 RR Autobiography
Sun Feb 03 2013 7:02pm |
Fatandre Member Since: 05 Oct 2009 Location: Reykjavík Posts: 402 |
So whats the trick here? 91 BMW 850CSI |
Sun Feb 03 2013 7:08pm |
DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257 |
Getting the right spec. resistor and mounting it so that if it gets hot, it doesn't melt any plastic.
Sun Feb 03 2013 9:26pm |
So whats the right resistor? 91 BMW 850CSI |
Sun Feb 03 2013 11:11pm |
Tim Hoang Member Since: 29 Jan 2008 Location: London Posts: 77 |
Any high power 50W-6R will do. 2005 RRS TDV6 HSE Java Black
Mon Feb 04 2013 1:31am |
So it is just enough to mount it for the turn signal right? 91 BMW 850CSI |
Mon Feb 04 2013 9:51am |
Only if you don't mind the double-speed flashing of the left indicator ("turn signal left")...
Mon Feb 04 2013 1:51pm |
Sounds like a plan.
Mon Feb 04 2013 5:57pm |
HICKY555 Member Since: 27 Jan 2013 Location: WORCESTER Posts: 208 |
GO TO POWERFUL-UK. WEB SITE , THEY ARE ALSO ON EBAY. I have just fitted resistors £10 for two they also give fitting instructions RANGE ROVER SPORT 2008
Sun Feb 17 2013 9:41am |
