Home > General > Not so bullet proof TDV8
Page 1 of 22 123 ... 202122>
simple1
At 49000 miles and with full dealer service history, the engine is seized/locked solid. Probable cause being turbo failure again! Car has had both replaced and after being parked for virtually three weeks yet again threw up dis error but no management light. Within few hundred yards of starting, there was a soft pop and the engine lost a bank of cylinders. Guessing it blew a pipe off somewhere. The RAC came out, played about and couldn't turn engine and starter just clicked. Bit more checking showed fuseable link has blown to starter.
Conversation with land rover dealer around heathrow area had RAC man out with computer, but only recorded fault is positive boost pressure error
So it looks like 9 grand engine replacement plus a turbo or two. About half the value of the car, having had it from new and properly looked after, am really at a loss as what to do with it given the problems it has suffered in its lifetime. Most of which seem to repeat and repeat. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #371667 Thu Jan 31 2013 1:14am
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Ouch! Sad
Sorry to hear this. Does your RRS have a warranty on it at present? 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #371693 Thu Jan 31 2013 9:21am
If you have already had your turbo/s replaced previously, then my guess is that the last time they went that they sucked some of the fins into the engine and whoever replaced your turbo/s hasn't picked up on this and has cut a few corners hence why your engine is now fooked. I'd throw it back at the people that replaced your turbo/s and ask them a few questions. Hopefully it was a main dealer that carried out the work previously, you might have half a chance in them footing the repair bill. Shocked
Post #371695 Thu Jan 31 2013 9:34am
^^^ Agreed, with that sort of mileage, I'd say a previous poor quality repair was to blame for it going so soon after. ON THE WAY: BMW F21 M140i
Post #371696 Thu Jan 31 2013 9:39am
not good...sorry to hear that RRS gone
Post #371734 Thu Jan 31 2013 12:51pm
Bodsy
Site Sponsor
if the work was done by LR (at £9k, it sounds like it) then I would be having a word with Liam@landrovercustomerservices send him a PM, he'll listen to your case properly and help you get a satisfactory response.
Its not unheard of for LR to provide a free replacement engine and fitted Whistle Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #371736 Thu Jan 31 2013 12:58pm
Bodsy, i think you have misunderstood, i think the op is saying it will be 9k to replace the now damaged engine. Wink
Post #371737 Thu Jan 31 2013 1:02pm
Bodsy
Site Sponsor
you're right, I did misunderstand, I thought it had been replaced before.
However, I would still talk to Liam.
My D3 had 100k, same year (07) and engine crashed when the timing belt tensioner broke. Discussion with the exec office at LR ended in them replacing the engine FOC. I'm now on 112k and all OK.
Had a mix of LR and Indi service history, but all to schedule so that should not affect your claim. Bodsys Brake Bible
See it HERE
Post #371738 Thu Jan 31 2013 1:08pm
simple1
Engine is original, the turbos were replaced by dealer at 8 months and two years by lr dealer. The error code and limp mode only appear when car has been parked up for long period. Am fairly sure it's a lung full of fuel as there were no engine failing noises but never say never. Big Cry will get injectors or heater plugs out of it at some point to have a look. LR did step up to plate to replace diff when it went out of warrentee but don't for one min think they will touch this. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #371740 Thu Jan 31 2013 1:45pm
wow so in it's lifetime this car's had 4 turbos? and mybe 2 more on the way? RRS gone
Post #371741 Thu Jan 31 2013 1:55pm
I wouldn't touch it, i would let L/R deal with it and let the diagnose the problem, i'd be very surprised if the turbo's are knacked though.
Post #371742 Thu Jan 31 2013 2:10pm
drdelrrs
I'd be surprised if Land Rover ignored your situation. At only 49,000 miles that's well behind the warranty mileage of 60,000 but I guess you're over the 3 years. I should think they would make a contribution of some kind (at least) as you'd still have significant rights under the Sale of Goods act which looks at a vehicles service life of at least 6 years.
For a TDV8 to have needed two sets of Turbochargers within such a low mileage is pretty bad and for the engine to failure I'd have thought JLR would want to investigate the cause rather closely.
Post #371745 Thu Jan 31 2013 2:12pm
Bodsy
Site Sponsor
Simple, Ive dropped you a PM with some more info which may be of use. Thumbs Up Bodsys Brake Bible
See it HERE
Post #371748 Thu Jan 31 2013 2:37pm
muddywheels
Milk Float Man
Definitely contact LRCS and see what they say - 49k is nothing and with all the problems you have had they need to help you out Shocked Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #371750 Thu Jan 31 2013 2:57pm
pjb
Sorry to hear that & puts my bitching about my car being driven at 92 mph whilst at a dealets into perspective
Hope you can get LR to assist given a from new owner Paul
L405 Loire Blue
Swift Conqueror 645
Abarth 500c
Post #371751 Thu Jan 31 2013 3:04pm
