Home > Maintenance & Modifications > Suspension Error
RRS_PAT
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Suspension Error
Hi All,
I am having issues with my suspension and would appreciate advice from you experts please Smile
So a while back I got the dreaded suspension fault unable to rise etc. Based on this I took the car to the Dealer and they did a magic trick where they turned lots of my cash into a new shiny compressor. Rolling Eyes
Since then I get a new error message (intermittantly) which is just plain suspension fault and the 'wobbly car' dash light. All the air suspension works. This only seems to happen on longer journeys.
I took it back to the dealers and they think I have a leak. They also said that these are a bit like looking for a needle in a haystack - giving an example of spending weeks to track down Big Cry
So they recommended that I check the car if it has sat for a while to see if any of the corners are down. It seems that the passenger rear does this.
So I have searched on here and read lots of threads but I could not find any straight forward advice on how I can try to track this down further - or help my dealer to do this with the minimum of time to protect my bank balance. Whistle
So your advice would be greatly appreciated,
Thanks,
Pat 2011 Autobiography Santorini Black
Post #368090 Mon Dec 31 2012 3:18pm
P7tey
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Try this thread
http://www.rrsport.co.uk/forum/topic29358....sion+fixed
May give you some starting points?
Post #368096 Mon Dec 31 2012 4:09pm
RRS_PAT
Thanks P7tey,
That looks a great starting point Thumbs Up I was searching for +suspension +fault so missed this.
Have to say, being non technical, I've broken out in a sweat just looking at the thread before I've even got near to doing anything to the car Shocked
So I think it will be going to the dealers. Does anyone know a good independent in the Basingstoke area please?? 2011 Autobiography Santorini Black
Post #368098 Mon Dec 31 2012 4:56pm
RRS_PAT
Hello again,
So my P+J is sat at the dealers having had a full leak test and fault code read. The dealer says there are no fault codes or leaks on the air suspension they could find Big Cry
Does anyone have an idea why my suspension light is coming on please?
Seems it is on longer journeys, where I travel at speed?
Any help gratefully received Bow down 2011 Autobiography Santorini Black
Post #371547 Wed Jan 30 2013 1:04pm
drdelrrs
I'd check the battery terminals are tight.
Post #371565 Wed Jan 30 2013 3:04pm
RRS_PAT
Thanks - I'll check that 2011 Autobiography Santorini Black
Post #371714 Thu Jan 31 2013 11:08am
