Home > Maintenance & Modifications > Front suspension arm bushes |
Jock 77 Member Since: 13 Apr 2012 Location: Falkirk Posts: 187 |
Hi there looking for some help ,I have a 2006 ,2.7 diesel Sport and my front passengers side tyre is starting to wear slightly on the outside edge. I was wondering if the bottom suspension arm bushes were worn if this would cause the wearing of the tyre. If so Iam looking into replacing the bushes on both front arms .
Fri Jan 25 2013 12:49am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4396 |
The bolts in the lower arm will be seized, unless they have been out before. You will probably have to end up cutting the arms to bits to get them off the car. Prepare for lots of cutting and grinding and probably swearing. I have done loads of sets, and every one has been the same.
Sat Jan 26 2013 9:07am |
Thanks Mikey
Sun Jan 27 2013 7:19pm |
