Home > Off Topic > Advice please on Gardening !!!!!! |
Bandit8 Member Since: 20 Oct 2012 Location: Essex Posts: 99 |
Now I know this has nothing to do with RRS sport but I was hoping that someone here can advise on the following.
Wed Jan 23 2013 8:17pm |
Gerico Member Since: 02 Jul 2011 Location: Essex Posts: 224 |
have a look at http://www.source4me.co.uk//calculate_buil....php?tab=0
Wed Jan 23 2013 8:26pm |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 |
Graded top soil costs a fortune, you might be as well rotavating what is there and tidying it up.
Wed Jan 23 2013 8:35pm |
Thanks Gerico and Codfather...
Wed Jan 23 2013 8:40pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8985 |
Topsoil. According to: http://www.dandystopsoil.co.uk/product-calculators-39-w.asp you need 24tonnes for 15.5m x 15.5m x 7.5cm (75mm / 3 inches). There are a number of these calculators on the web so it's worth checking a couple of them for consistency.
Wed Jan 23 2013 8:47pm |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
You might need to any the concrete in two parts to prevent cracking a few days apart |
Wed Jan 23 2013 8:59pm |
JC1 Member Since: 24 Oct 2009 Location: Berkshire Posts: 939 |
If you only taking off the top 3" (75mm) one 8 wheeler load of topsoil would just do it, you should be able to get good screened soil by the 8 wheeler load (approx 15m3) for £200 - £250 MY10 3.0 HSE Santorini Black, Ivory Premium & extended leather, privacy, paddles, diamond turned alloys, Ipod lead that charges, tasmods, rrsport.co.uk stickers
Wed Jan 23 2013 9:02pm |
Thanks for the replies. As I will not be doing this I will of course gauge some advise from the cabin supplier which i will be hoping to see this weekend and also the concrete supplier, whoever that may be
Wed Jan 23 2013 9:09pm |
I used one of them for my garage, as I needed 9x9m x 8inches thick, I did it over two weekend, and the first he overcharged me by about 1m3, second weekend I docked him the 1m3 and sent him on his way! I wouldn't trust them at all. Best hiring a mixer and doing it yourself. Put a base of broken bricks or type1 aggregate and create your base by putting up shuttering (thick planks will do so they don't weave and wobble) then just mix away to your hearts content for the weekend! As npinks says if you do it in two halfs and leave the plank in this acts as an expansion joint Cheers Dave MY10 TDV6 SE (debadged ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps! Gone: a comprehensive list of imprezas and a Merc ML AMG |
Wed Jan 23 2013 9:21pm |
Is there any problems if you get it shutterd up and you pour the concrete in one go rather than two then? It is what it is and I am what I am.... |
Wed Jan 23 2013 9:32pm |
Once it hardens it can crack, which itself wont pose any problems if it is just a shed, but it is a shame when you can avoid it . on 9x9m, I did mine in 4 quarters, no cracks at all
Wed Jan 23 2013 9:41pm |
Thanks Dave for your help.
Wed Jan 23 2013 9:59pm |
Batch mixers 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Jan 24 2013 12:13am |
5mx4m shouldn't need an expansion joint unless the concrete is very wet when laid (or it's laid when it can be subjected to freezing temperatures). Adding water to ease pouring increases the shrinkage potential - concrete should only have just enough water to hydrate the cement. Anymore than that will cause shrinkage. As a point of reference, large slabs are often cast as 6m wide strips (because steel frame grids are often at 6m spacings.)
Thu Jan 24 2013 12:32am |
