![]() | Home > Faults & Fixes > 3.6 TDV8 Just stopped |
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 ![]() ![]() ![]() |
Know this from my father's old FFRR MY02, where similar issue was caused by a faulty fuel pump between the fuel tanks - not sure if same set-up is on the RRS. |
sampson321 Member Since: 15 Jul 2012 Location: bristol Posts: 8 ![]() ![]() |
Tried to start again today now coming up with a fault code of p1623. Does anyone know what this actually means apart from ECM security code. |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
Turns out I have one turbo seized solid and one turbo full of oil. |
pjb Member Since: 04 Mar 2008 Location: Sunny Oxon Posts: 213 ![]() |
Trainbow Member Since: 07 Aug 2012 Location: Windsor Posts: 1 ![]() ![]() |
I have just got mine back having had two turbos fitted. It stopped dead under hard acceleration, one stuck solid the other full of oil.
Exactly the same with mine. Near side turbo seized and the off side full of oil. Iv gone for a gamble with mine though and only changed the one turbo. Done 400miles so far and not missed a beat. |
Sterling69 Member Since: 23 Jan 2013 Location: London United Kingdom Posts: 2 ![]() ![]() |
Just had the same happen to mine, pulled out of garage after filling (yes with Diesel) got 100m up the road power went and came to stop in the road, Restarted but only a very lumpy tick over still no power and a load of smoke.
Hi Sterling69
Hi Sampson321
