![]() | Home > Maintenance & Modifications > OEM Style LED Signature Halo Lights for 05-09 |
sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588 ![]() ![]() |
After much searching I have found what I believe to be the best OEM style signature LED rings for 05-09 headlights, and i'm sure you will agree they look the dogs
More pics in gallery This pic was taken at the same time with camera on normal settings and only the LED's on, as you can see they are super bright and look like the xenons are on in the picture as the camera could not capture the detail of the individual lights without messing with the settings, even then they look blue in the pics but they are bright white.
------------------------------------------------------------------------------------------------------------------------------------------- Update Options & costs below guys, if anyone is interested or has further questions you can contact me on here Option 1 � Exchange This consists of me sending you out a set of headlights already fitted with the DRL�s, which you can then fit into your car and send me your old ones back as a replacement which can then be modified and sent on to the next person, meaning you are not without the use of your car for a few days. Option 2 � Existing This consists of you removing the lights from your car and posting to me, I will then fit the DRL�s and return to you ready for you to fit into your vehicle, if next day courier is used you should only be without your lights for a few days Option 3 � Same day This is for anyone local to Wolverhampton who doesn�t mind driving to me and leaving their car with me for the day so I can carry out the alterations to your existing headlights and then fit back into your vehicle for you. Costs Signature DRL�s supplied & fitted �280 Painted Internals �50 (optional extra only when doing DRL�s at same time) Courier each way if required �12.90 with www.directcouriersolutions.co.uk A couple of you have asked about doing a DIY, I can do a set if anyone is interested that consists of 4 x rings & the DRL switch inc wiring loom to make it work automaticly on engine start/stop etc for �75 delivered to anywhere in the mainland uk if anyone fancies having a go at it, or �55 if you just want the rings with no wiring loom ![]() Full black internals
Sag Member Since: 08 Jul 2009 Location: Leicester Posts: 564 ![]() ![]() ![]() |
They look ace |
Welderman Member Since: 14 Jan 2013 Location: Chorley, Lancashire Posts: 146 ![]() ![]() |
i watching this space |
Glohh Member Since: 20 Sep 2012 Location: England Posts: 44 ![]() ![]() ![]() |
Very nice Sparky. I'm impressed |
Wolverhampton, so not too far from you |
Thanks Glohh, i'll swap you a set for your "Coming soon a state of the start tail light" ??? ![]() ![]() |
Glohh, I'm not one to pick fault but think your sig should read "state of the ART tail light" |
The more I look I want lol, will you be offering a fitting service or just supply of the lights on a exchange basis
I will gladly do a fitting service if you dont mind coming to me, other than that I can supply instructions to do final connections as most of its done off the vehicle so shouldnt be a problem to do last bit yourself, its easy enough and only takes 15-20 min |
I can also do an exchange basis, I will have a look into the cost of purchasing these lights & see if I can do a set to sell on & then mod the replacements sent back to me if thats what people would prefere? |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
I'm very interested - when will you be ready for your first customer |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
I'd be interested in a set. Question can the led on smaller ring be rotated so that it's at the top (12 o'clock)?? |
Zippy Member Since: 16 Jun 2012 Location: London Posts: 16 ![]() ![]() |
Could you send a kit and I do it myself? |
cmcb Member Since: 16 Jan 2013 Location: Edinburgh Posts: 33 ![]() ![]() ![]() |
Looks really good to me- what would you be looking to charge? RRS TDV8 HST
