![]() | Home > General > Locking Gas Cap/Door |
d3matt Member Since: 11 Jul 2005 Location: Oxfordshire, UK Posts: 730 ![]() ![]() ![]() |
Yes, it is just a push latch, but then it does still lock with the central locking. Well the UK ones do anyway. I'm sure they all do. Matt
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 ![]() ![]() |
Both LR3 and Range Rover Sport do not have a locking fuel filler door in North America. Yes, even a loaded Supercharged one. It does not lock with the doors. Some other markets do have the lock installed. (And no, the alarm does not sound if you pry open the door when it's locked.)
mavromatis Member Since: 20 Oct 2005 Location: Seattle, WA Posts: 7 ![]() ![]() |
Can someone take a photo of their UK versioned RRS gas compartment? I want to see what parts are missing from the US version... it seems like there is a hole near the bottom of the touch-latch system where a solenoid pin would be. Is the wiring there on the US spec car that all we would need is the missing solenoid assembly? If so, how do we get the part number? I'd really like to install that part... Thanks, Danny |
If you look closely, you can see where the locking solenoid "pin" should pop out of. I think the mechanism would need to be installed from behind the compartment and I don't think the wiring is there, either. But I didn't tear apart either vehicle.
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
Hi Danny
North America generally uses 315 MHz for alarms, FYI. |
Edit: So this part is more related to the alarm, than the central locking system, correct? Hence the 433 MHz Frequency? Thanks Martin! This is very interesting... does anyone have a service manual available for the Sport yet? When I get delivery of my Sport, I will check out the side panel area for a connector... I'm wondering if the actuator just requires power and the car sends a 433 Mhz signal to tell it to lock... but at only £14.10, I doubt it. Seems too complex for such a thing. I wonder what the interface is... Do we have any LR service technicians on this board? |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
I'll take some pictures tomorrow afternoon of mine if that helps. They'll be online this time tomorrow for you. L319 D4 HSE
