Home > General > Transmission Fault & HDC Unavailable, suspension lowers |
lee157 Member Since: 07 May 2010 Location: in the middle Posts: 19 |
The switch is under the dash near the brake pedal. If you pull the panel away under the steering column with the vent in, it will give you a clear view, a simple turn of 90 degrees and it's out I think. Just a point, be carefully pulling panels in the cold weather as the plastic clips can easily break. Lee |
Wed Nov 07 2012 3:13am |
pa81 Member Since: 05 Nov 2012 Location: Hillingdon Posts: 9 |
Thanks you all for your advice, I will let you know how I get on |
Wed Nov 07 2012 2:09pm |
Kimmea Member Since: 10 Jul 2012 Location: Aberdeenshire Posts: 259 |
Pa81 how you getting on with our fault.... Any updates ? |
Sat Jan 05 2013 2:19pm |
rogerpop Member Since: 14 Jul 2012 Location: blackpool, Lancashire Posts: 14 |
Had same problem on mine. It was brake light switch on its way out but brake lights were still working fine. I had it fixed at specialist who plugged his machine in and then charged me £100 for a £10 part and took him 5 minutes to put in. |
Sat Jan 05 2013 3:13pm |
Jamie-G Member Since: 18 Nov 2012 Location: oxfordshire Posts: 13 |
Hello I just replayed to a similar topic, I had this problem on my 57 plate rrsport thats covered 50k
Fri Jan 11 2013 8:08pm |
Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187 |
Hi Jamie-G, I had similar problem with my car and all the problems were solved when they changed the fuel filter. I hope it helps 2008 RRS TDV8 HSE, Java black, Alpaca,..... |
Wed Jan 16 2013 9:22pm |
