![]() | Home > General > Rear Bumper Respray. |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
£160,my rear is being done at the moment due to a van rolling into it before christmas.The £160 is for the front but dose include removal and refit. |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Thanx for the heads up |
Glohh Member Since: 20 Sep 2012 Location: England Posts: 44 ![]() ![]() ![]() |
Hi Peachy, The bumper you have is it primed and flat without imperfections? If so… should be straight forward. The only real worry is the quality of materials that are used, as cheap black may look black but under sunlight will reflect back a bronze like colour very common with cheap body shops. Also make sure the bumper is oven baked as this will bake the top layer “lacquer” and the under coats. This will help prevent easy surface scratching and help with longevity. As this is a bumper and more venerable to scratching would definitely check lacquer quality. For a decent job from a respectable place it would cost approx. £250 good quality materials. For a job that looks good and will cause issues later will cost £80-£170. Hope this helps Glohh. Automotive light designers and manufacturers. Available now The GL-3 Taillight for the Range Rover Sport. www.glohh.com www.facebook.com/glohh |
Well I'll see what it's like when I get mine back,it does come with a lifetime guarantee though. |
