Home > General > Fridge for the boot?
Bomber H
Bit of an oddball question, but does anyone know of a portable camping fridge that would fit nicely in the boot and allow the boot cover to still be pulled closed?
Ideally a fridge with an opening door rather than a lid. 2016 VW Golf GTD DSG
2007 Exige S British GT SE
Gone : 2011 3.0TDV6 HSE, Stornoway Grey, Ivory, Piano Black Trim, Paddleshift, Privacy Glass, Side Steps, Mud Flaps, Heated Steering Wheel, Timed Climate & Remote Park Heating Smile
Post #369253 Sun Jan 13 2013 11:12pm
mse
Loads of expedition fridges of different sizes, have a look there.
Do you need a fridge or cooler? Cooler for the boot is an accessory from LR for example Mike
2014 Facelift Discovery
Post #369255 Mon Jan 14 2013 12:09am
Bomber H
I want to keep food such as meat fresh, so I guess a fridge is what is required.
Is 'Expedition' the make? I'll take a look, as well as looking at the LR offering Thumbs Up 2016 VW Golf GTD DSG
Post #369284 Mon Jan 14 2013 10:39am
pko
England 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
I use a waeco coolfreeze cf35. It's a mains/12volt cooler or freezer, depending how cold you set it. It's silent, sits in the boot area and works brilliantly as a freezer in outside temp. of to 40 deg. I did have a dometic combicool, but the compessor fitted inside it usede to rattle and clang going over bumps in the road. I have got a land rover cooler box but considering it's size, it is very limited as to what you can get in it, plus the fan is noisy.
regards
p
Post #369285 Mon Jan 14 2013 10:41am
The LR one is more of a portable cooler bag as mse says.
I doubt you'd be able to keep meats etc in it for any prolonged periods to be honest. Neutral ON THE WAY: BMW F21 M140i
Post #369286 Mon Jan 14 2013 10:42am
Bomber H
I'm only talking 2-4days for long weekend trips, BBQ/Fry-up type food.
Just looked at the LR cooler bag, looks too small and low tech in comparison to what I had in mind.
I'll look into the Waeco type Thumbs Up 2016 VW Golf GTD DSG
Post #369288 Mon Jan 14 2013 11:00am
duckworthparts
Site Sponsor
check out Engel fridges, might be abit excessive for your needs but they are brilliant Sophie Alltoft
Send a paypal payment direct using this link www.paypal.me/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: danroberts@duckworthlandrover.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Can also supply OEM & Aftermarket parts
Post #369292 Mon Jan 14 2013 11:17am
Bomber H
Will do thanks Thumbs Up
I also need to consider how much drain they will have on the battery if the car is stationary for several days whilst its plugged in Question 2016 VW Golf GTD DSG
Post #369295 Mon Jan 14 2013 11:22am
Yes, no point having lovely cold food if you can't drive the bloody car home Laughing ON THE WAY: BMW F21 M140i
Post #369297 Mon Jan 14 2013 11:26am
lots of info on disco3 as lots of them have the engel due to the very low battery draw
Post #369301 Mon Jan 14 2013 12:03pm
Streaky
United Arab Emirates 2008 Range Rover Sport Supercharged Alaska White
Any fridge capable of keeping meat fresh for 2-4 days without running the engine will drain the battery to a point where the car won't start.
The Engal fridges are one of the best on the market for power consumption but it will still draw around 3-4 amps to maintain 2-3 degrees C temps needed for meat.
If you are driving alot of the time to campsites etc then parking up over night with the fridge running it won't be a problem. The Weaco's are a good fridge but they cycle more often than the Engals due to their poorer insulation and less efficient compressor.
Dont contemplate these cooler box's with cool or warm settings...they drain more juice than they are worth plus they arn't fridges anyway! Ra-Ro Sport Super Dooper Charged.
Ford F350 Super Duty Prototype.
Ni$$@n Patrol 4.8 Overlander.
Post #369312 Mon Jan 14 2013 1:05pm
mse
As per the above - expedition type units are the type rather than a brand...Ive had Waeco and it was a good unit - equally Engel. ARB also do one eg: http://www.lrsshop.co.uk/category/catalogu...es/fridges which my friend has in the back of his 110 24/7
Personally whenever i had had a fridge (or any product running continuously) I've had a dual battery system - there is never a good time to be without your main battery to start the car, so to isolate it when parked is a great idea Mike
Post #369359 Mon Jan 14 2013 6:52pm
Bodsy
Site Sponsor
I use an engel MT45 which is a great fridge. Can also be used as a freezer.
Runs 12v or 240v. Very low current draw of around 2 amps.
These halfords type coolboxes will draw about 10-12 amps and your battery will be flat in less than one night.
Your car has space under the bonnet for another battery, the most popular being the Optima YellowTop d34.
You need a split charge system which could be a very basic system or more intelligent such as the traxide Tronics split charge (which is what I use).
I can run a full weekend without moving and still start on the Sunday afternoon.
If I was buying again for low power usage I would choose in this order
Engel - very low power usage
ARB - slightly higher power, but more insulated body
Waeco - more like an engel
Hope that helps
Btw, when the engel isnt in the car, its often used as a beer cooler in teh house as it does a great job of cooling everything down very quickly. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #369365 Mon Jan 14 2013 8:06pm
Bomber H
OK, very useful information, so thanks all Thumbs Up
The particular trip away I plan to use the fridge for is not until the end of August, so I've got time to save up for a fridge if I want to buy one, however I note that Engel offer a hire service - which could be perfect! 2016 VW Golf GTD DSG
Post #369453 Tue Jan 15 2013 1:35pm
Streaky
Also available for hire through MPS Trading.
http://www.engelfridges.co.uk/
I've dealt with these people before...good reliable company. Ra-Ro Sport Super Dooper Charged.
Post #369457 Tue Jan 15 2013 2:28pm
