Home > General > Snow Chains
mse
Snow Chains
Is there anywhere i could rent snow chains for a europe trip for the sport's 20inch wheels (that isnt going to rip me off)?
I can access them for 16inch wheels...but i dont know anyone with a pair for 20inch wheels Mike
2014 Facelift Discovery
Post #369206 Sun Jan 13 2013 5:11pm
I used a place in Maidstone (Kent) a few years ago Mike (albeit for 17" wheels)
Think it was £50 odd for a week. Will try and find them for you.
I picked them up on the way down to the Chunnel. ON THE WAY: BMW F21 M140i
Post #369217 Sun Jan 13 2013 6:52pm
mse
Thanks, ill do a quick search.
Land Rover kit is £600+! Mike
Post #369232 Sun Jan 13 2013 8:44pm
Is this any help Question
http://www.roofbox.co.uk/scripts/rbvehsel4...8NCEOgKc3J
Post #369235 Sun Jan 13 2013 8:59pm
Or purchase snow socks
http://www.roofbox.co.uk/scripts/rbvehsel3...55%2F50-20
Www.roofbox.co.uk/cc might discount them due to caravan club discount
Post #369236 Sun Jan 13 2013 9:02pm
mrfrog
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
Snow socks not guaranteed to be accepted as a suitable alternative in the alps.
Www.snowchains.com do rental
(Edited to change website name)
"Roads ? Where we're going there are no roads." Back to the future.
Post #369239 Sun Jan 13 2013 9:41pm
mse
Thanks - yes i had come to the conclusion that snow socks wouldnt be acceptable in the alps for snow chains.
I had looked at the spikes (which are the same as the LR ones) when googling earlier...the advantage is they are the same as the LR ones...the down side is they require the plate fitted to the wheels before you leave and are expensive.
Do any of the normal chains work? or will they destroy something? Mike
Post #369242 Sun Jan 13 2013 10:01pm
mrfrog
I've no idea I'm afraid, I've only ever been in a defender or P38, not taken the RRS to the alps yet.
Post #369273 Mon Jan 14 2013 9:34am
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
MSE, this topic was up just a few days ago.
According to Land Rover (Look in manual p.239),
snowchains is NOT to be mounted on 20" rims,
the danger of destroying brakelines and other stuff
is apparent, due to not enough clearance.
The recommended rims for snowchains is:
17x8" 18x8" and 19x8", and if fitted,
ONLY ON FRONTWHEELS.
Edit:
Took a look on the Spikes Spider Sport,
and guess thyat thesde c o u l d be used on the car, since there
seems to be nothing on the inside of the rim.
Best regards
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #369280 Mon Jan 14 2013 10:27am
Seems they have gone belly up as I can find no details of them now. Confused ON THE WAY: BMW F21 M140i
Post #369283 Mon Jan 14 2013 10:37am
mse
Edit:
Best regards
Uffe
Sorry thats not accurate any more and could be you using an old manual - for the 2013MY Range Rovers you can use snow chains on the front on 20inch rims...Land Rover recommend you dont have any that hook around the rear of the tyre (between the wheel and suspension...this is because you will destroy everything including brakes).
So you have to get the type that dont hook around the rear...there are a few on the market - land rover recommend the spike spiker (which is who make the genuine version). They bolt a plate on the wheels and then clip to that.
There are some others of better design that attach to one nut etc...the key is to make sure the chains are on a max of 3/4 of the tyre:
Quote:
If it becomes necessary to fit traction devices,
the following points must be observed:
• No traction devices should be fitted to the
rear wheels.
• Single sided spikes-spider traction devices
can be fitted to the front wheels of vehicles
fitted with 18, 19 or 20 inch diameter
wheels.
• The wheels and tyres fitted must conform
to the specifications of the original
equipment.
Page 196 BTW! Wink Mike
Post #369360 Mon Jan 14 2013 6:58pm
SVR575
Correct mse. Thumbs Up SVR 2018 in Santorini Black.
Post #369362 Mon Jan 14 2013 7:24pm
ikeysolomon
United Kingdom 2013 Range Rover Sport Supercharged Adriatic Blue
I work out in the Alps during the ski season and while I carry a set of chains (requirement if you don't want to get turned around) with Ice & Snow tyres have never had to put them on and I go to some fairly remote chalets.
Ikey
Post #369373 Mon Jan 14 2013 9:26pm
