Home > Maintenance & Modifications > 'Spray' Washer Jets |
you can adjust them using a pin RRS gone
Wed Jan 09 2013 4:05pm |
Cheney Jawa Member Since: 25 May 2012 Location: Birmingham Posts: 89 |
I was more thinking along the lines if there were any aftermarket spray/mist jets available? Owner of MY13 RRS Red Edition, Santorini Black, Ebony with Lunar, Privacy Glass & Exterior Design Pack |
Wed Jan 09 2013 4:09pm |
Morpheus-RRS Member Since: 29 Oct 2012 Location: Lanarkshire Posts: 83 |
I know what you mean and was also surprised that the RRS still had the crappy jets fitted, I've had BMW's for the last 8 years and they have all been fitted with the spray type and also my fathers 04 Audi is fitted with the spray type, they are far better at putting a good dose of water over the whole screen.
Thu Jan 10 2013 12:40am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Perhaps you could open the window, lean round and put your finger slightly over the jet, a bit like you would a hose to produce a wider spray pattern
Thu Jan 10 2013 9:18am |
Mike_S Member Since: 03 Dec 2012 Location: Dunstable Posts: 15 |
My 06 has 4 jets and with good adjustment they cover the whole of the screen. If the new model only has 2 can you retrofit the earlier type? |
Thu Jan 10 2013 10:37am |
New ones still have 4 Mike ON THE WAY: BMW F21 M140i
Thu Jan 10 2013 10:51am |
defender_uk Member Since: 08 Aug 2006 Location: North Yorkshire, Pickering Posts: 169 |
I wonder if the ones off the RRE woiuld fit? |
Sat Jan 12 2013 1:42pm |
sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588 |
True True, my merc vito van has the best washer system ive ever come across on any type of vehicle. |
Sat Jan 12 2013 2:53pm |
