Home > Maintenance & Modifications > New to London - good place for service?
crimmo
Ireland 2006 Range Rover Sport TDV6 SE Bonatti Grey
I have to drive from Dublin, via Holyhead, to do some work in London and I figured it was a good chance to get a proper service without getting fleeced as normal in Dublin. I have a few minor issues with the car so again good chance to get them sorted such as a dent in the car and the central locking is acting up (the driver door won't lock and the rear passenger door only opens after three beeps of the key).
I am very open to going to an independent garage that specialise in Land Rover if anyone can recommend one, otherwise which approved service centre has good reports. I will be staying in London and working out Oxford way so anywhere on the M40 corridor would be perfect. However happy to consider anywhere in general London area if a compelling reason.
All help gratefully appreciated.
Crimmo
Post #368489 Sat Jan 05 2013 10:19pm
fkarim
Have a look at the sponsors page. Following two London dealerships are forum sponsors:
1. Hadley Green (Barnet, North London) forum user James @ Hadley Green LR
2. Lookers (Park Royal, West London, on the A40) forum user Lookers Park Royal
Expect good service. If you mention the forum, a discount too.
Post #368494 Sat Jan 05 2013 10:48pm
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
Lookers park royal is the place to go. Period. Vadim A.
Post #368503 Sun Jan 06 2013 12:48am
AZIZBBU
United Kingdom 2008 Range Rover Sport TDV8 HST Stornoway Grey
Always had mine serviced at Lookers Park Royal and never had a problem, but then that was when James @ Hadley Green LR was working there. I think it was because of him being so active on this forum that swung it for me to get my sport serviced there. TDV8 HST STORNOWAY ON A 58
Full Alpine multimedia install
Road Angel Pro
PS3
Post #368507 Sun Jan 06 2013 2:37am
Paddi
Welcome to London. If you don't want to be fleeced I'd suggest you avoid LR Dealerships like the plague
You don't say what the dent problem is exactly but any good bodyshop should be able to fix it.Repairing and painting any panel seems to be about �150 at a good independent. I can strongly recommend Langley Autocraft in Kings Langley near Watford (01923 269456) for painting and they will lend you a little courtesy car at no additional charge. If its just a small dent perhaps you could use a smart repair company.
Your central locking issues are probably just faulty latches; they often fail. Parts are about �40 per door ordered from site sponsor Duckworths. Fitting is a bit fiddly but anyone who has done it before should able to do it in an hour per door. There is a very detailed how to with pictures on our sister D3 website. I did my drivers door latch in the summer with no problems. Langley Autocraft would probably have a go (they do servicing as well as paint) but I would give them the parts and copy of the how to guide. Speak to the boss who's name is Keir first?
Good luck Thumbs Up 2008 MY Java Black TDV8 HSE
Post #368522 Sun Jan 06 2013 1:21pm
Paddi
Crimmo - you have a pm 2008 MY Java Black TDV8 HSE
Post #369021 Fri Jan 11 2013 4:16pm
Paddi
Crimmo - you have another pm 2008 MY Java Black TDV8 HSE
Post #369340 Mon Jan 14 2013 4:19pm
