Home > General > HDC fault at startup
Coxlong
Get an error saying "HDC fault system not available" when I start my range rover.
Never seems to cause anything else or any problems starting ,just this message.
Any idea what it is?
Post #352570 Wed Aug 01 2012 12:27pm
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
hi, i had this when my battery got low. you drive every day? i dont so i hook it up to a charger now and then. when charged to full charge it did nt appear. Otherwise a new battery?
Post #352588 Wed Aug 01 2012 1:59pm
Gibbsy1966
England 2011 Range Rover Sport 3.0 TDV6 HSE Lux Sumatra Black
Had the same problem on mine, eventually it would start then immediately stall...had a new battery fitted and no problems since (well with the HDC anyway Rolling Eyes ) BMW 530D 2011 still here
Porsche Boxster S gone - RRS Supercharged bought to transport 2 Tibetan Terriers!!
Post #352590 Wed Aug 01 2012 2:20pm
Coxlong
Quite a strange one, car's used regularly and never had an issue starting!
I might try sticking some juice into it, otherwise might be new battery time!
Cheers guys.
Post #352592 Wed Aug 01 2012 2:39pm
Kimmea
Scotland 2013 Range Rover Sport SDV6 HSE Fuji White
coxlong What was the outcome as mine has just done the very same
Post #368452 Sat Jan 05 2013 3:10pm
1860Gavin
United Kingdom 2006 Range Rover Sport Supercharged Zermatt Silver
Had same fault in Dec on my SC. Battery check read unservicable. New battery cured fault. Very Happy
Post #368454 Sat Jan 05 2013 3:45pm
madmackie
United Kingdom 2005 Range Rover Sport TDV6 HSE Bonatti Grey
Same here new battery in december hdc fault gone
Post #368753 Wed Jan 09 2013 5:21pm
Surely worth checking the alternator too in case that's whats causing the poor battery too, no ? ON THE WAY: BMW F21 M140i
Post #368755 Wed Jan 09 2013 5:26pm
madmackie
Possibly but my friend had the same issue last week Had it checked they said the alternator ( he had the alternator replaced with a recon one 15 months ago by the same company the warrenty was of course out ) so he paid the £220 bill for another alternator guess what still got the hdc so he needs a battery now if he wants to get rid of this message.As everyone knows once started and run you wont get it again untill the car has stood (usually overnight ) it happens on first crank in the morning but yes woth checking the alternator
Post #368761 Wed Jan 09 2013 5:37pm
bazalab
England 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Hi All
Just for similar info to this thread - I have had the HDC fault on my 2006 HSE for a while and then the very morning I wanted to hook up to caravan to go away before Christmas, battery dead! Never done that before. Green Flag out within half and hour, jump started car. Was found to be charging by alternator at 14 amps (he said) so it was a battery problem, not the Alternator (he said).
Did not turn engine off until covered 90 miles, restarted no problem and completed 120 mile journey, battery well charged. Never failed since, but I expect the colder spell ahead will be the test.
Still getting HDC fault message so hope it disappears when battery replaced. New battery will be fitted shortly, hope keeps going meanwhile.
Baza Baza G
Post #368967 Thu Jan 10 2013 11:13pm
madmackie
If the alternator is charging correctly the new battery will cure it
Post #368969 Thu Jan 10 2013 11:23pm
bazalab
Thanks Madmackie!
In fairness I must assume it is the original battery as it only had 34k on two years ago when I bought it so no complaints now at 55k!
Baza G Baza G
Post #368972 Thu Jan 10 2013 11:38pm
madmackie
As I've said earlier my car is a 55 plate so it's just 7 yrs old I had the problem new battery sorted what I will say is get the right battery don't be fobbed off if its a diesel it need to be at least 90 amp with a cca of 900( cold crank ampage) if it doesn't have this don't fit it as next year when it's cold you will have the same issue.i got mine off eurocarparts delivered with 3 yr warranty it was 100amp with a cca off 950 for £89 using promo code battery 15. If you need the link let me lnow
Post #368974 Thu Jan 10 2013 11:46pm
bazalab
Thanks much appreciated and I will get back to you if needed!
Baza G Baza G
Post #368983 Fri Jan 11 2013 1:30am
