Home > Technical > Suspension.......
iz6byo
2006 Range Rover Sport TDV6 HSE Buckingham Blue
Suspension.......
hi everyone
this evening while i drive the car an error appears on dash.
suspension problem, only the standard height is available.
i switched off the engine and the compressor still was working.
i disconnected the battery.
anyway with the Fualtmate i got the faults as i show you:
the tested
not tested:
now if i plug back the battery the compressor starts and never stops.
can you help me to find the solution?
thanks a lot.
Piero
Post #368269 Thu Jan 03 2013 12:07am
Bodsy
Site Sponsor
Piero, ignore the Non tested faults.
The problem sounds like your compressor relay is sticking. Very cheap to replace with genuine. As a test, you can test it by using one of the other relays in the fusebox in the engine bay.
If you don replace it, the compressor will overheat and €10 relay is better than €500 compressor! Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #368270 Thu Jan 03 2013 12:11am
iz6byo
hi Bodsy
do you mean the relay near the battery?
all relays are in the engine bay?
thanks
Post #368271 Thu Jan 03 2013 12:17am
Bodsy
Site Sponsor
Some relays are inside the car, but the compressor relay is in the fusebox next to the battery. I can't remember which one, but it is listed in the lid of the box. Bodsys Brake Bible
See it HERE
Post #368273 Thu Jan 03 2013 12:37am
Bodsy
Site Sponsor
From Wiggs gallery on Disco3 Thumbs Up
Pointing to the space for the compressor relay.
http://www.disco3.co.uk/gallery/displayima...fullsize=1[/url] Bodsys Brake Bible
See it HERE
Post #368275 Thu Jan 03 2013 1:08am
iz6byo
Bow down Bow down Bow down Bow down Bow down Bow down Bow down
Thanks a lot for your answers.
As you can image,this morning I connect back the battery and all seems ok.
Anyway I change the compressor relay with the rear window heater.
I tried only for 2 minutes,up and down and seems working properly.
Now I try for one hour and I'll give you some feedback.
Thanks again...
Post #368279 Thu Jan 03 2013 8:58am
iz6byo
Hi
Good news...
All is going properly...
The system works and goes up and down.
So I think was the relay...
I'll replace it this week.
Thanks again for your help
Piero
Post #368332 Thu Jan 03 2013 7:21pm
