Home > Wheels & Tyres > Cracked Alloy - what to do?
simple1
Was always told that anything 4x4 should have Tyres replaced in sets of four by tyre blokey. Obviously in his interest when in 2002, a set of Tyres was just into four figures on RS4. Have wised up a bit since that. The difference in rolling radius is only thing that will upset centre diff and that's 8mm between new and slick/bald. It is good to have pair of Tyres on an axle so may be prudent to swop back and fronts so replacement odd is on rear. Only a thought Whistle 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #368053 Sun Dec 30 2012 10:53pm
wilburn
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Nara Bronze
Many thanks to Duckworth parts, alloy wheel and tyre arrived at 8am this morning and is currently with local tyre place having tyre from cracked alloy fitted to it.
I am going to get the cracked alloy wheel professionally repaired then use it as a spare with the 'free' tyre that came with the alloy wheel from Duckworth Parts.
I am therefore looking to sell the spare wheel which is 255/50/R19 107Y Continental Cross Contact.
Any offers?
Thanks
Paul
Post #368199 Wed Jan 02 2013 10:33am
Paddi
Good solution. Remember though that the full sized wheel will look rather prominent fitted in the spare position so obvious to the local scumbag spare wheel thieves. Unless you already have one, fitting an anti-theft device would be highly recommended. 2008 MY Java Black TDV8 HSE
Post #368210 Wed Jan 02 2013 12:51pm
wilburn
Yes, that was on my mind also but arn't the security devices around £170 ?
Post #368213 Wed Jan 02 2013 1:17pm
Paddi
Not quite that bad. You can buy one from a forum member called Ray. Think mine bought 6 months ago was about £85 delivered. Link to the details: http://www.rrsport.co.uk/forum/topic23416....=protector 2008 MY Java Black TDV8 HSE
Post #368214 Wed Jan 02 2013 1:34pm
jakeob
England 2007 Range Rover Sport TDV8 HST Java Black
Last time i had a cracked alloy i just got it repaired by a specialsit,,, £40 cash
Thats was after trying to claim against BMW, as common fault with run flats on 19in rims
Post #368226 Wed Jan 02 2013 3:43pm
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
Result! Thumbs Up
Jim
Post #368387 Fri Jan 04 2013 5:41pm
Porkchop
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
Eek, I drive a BMW on 19"s with run flats....... Whats the issue Sir?
Post #368620 Tue Jan 08 2013 6:45am
jakeob
Porkchop
Have a look at this link
http://www.bbc.co.uk/watchdog/consumer_advice/bmw_latest.shtml
I ended up telling them to stick there 50% contribution to 2 new wheels as they would not agree to me fitting NON runflats..
Post #368685 Tue Jan 08 2013 6:18pm
Bodsy
Site Sponsor
With all the gubbins on these cars, working on and off road, a slight difference in tyre shouldnt make a difference really.
Yes, ideally change a pair, but in real world, it will be fine.
I've driven 3 months on 3x 19" with MTR's and 1x18" with at2. No problem at all.
I'm sure if I was racing it, it would be different, but no errors or detrimental effects at all. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #368689 Tue Jan 08 2013 6:32pm
Porkchop
jakeob wrote:
Porkchop
Interesting read. Thanks for sharing that. Bloody large corporations trying to bale out on their customers!!!
Post #368712 Tue Jan 08 2013 11:34pm
AndyPollard
22in super sport overfinch
I have just cracked my wheel and its gone to be repair as my local tyre shop sent my jag wheel off to be welded a few weeks ago and all sorted and no problem so let hope it works with the overfinch ! It cost £80 Black Overfinch
Post #370980 Fri Jan 25 2013 7:45pm
