![]() | Home > In Car Electronics > 7 pin and 13 pin dual wiring possible? |
Can a car be dual wired to have an old fashioned 7 pin alongside the new 13 pin electrics?
WolfgangK Member Since: 28 Dec 2011 Location: Heilbronn Posts: 86 ![]() ![]() ![]() |
May be, you find something here
The only way you could dual wire is to tap in to whichever you fit and run a second set.
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
I use a twin to 13 adapter for my new van, easier than purchasing another set of highly priced LR electrics and I don't need to worry about the bike rack too |
Gooser Member Since: 28 Dec 2012 Location: Warrington Posts: 7 ![]() ![]() ![]() |
I have a 7pin to 13 pin conversion lead, cost £25 from Towsure |
Cheers for the replies |
CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59 ![]() ![]() |
as long as you dont connect two plugs at same time (no usual) you are ok if you "double" the electric installation, that is, double wire from the car to the 7 an to the 13 pin socket.
13 Pin has an additional feed i thought - so i could believe something wouldn't work going from the Black/White 7 to 13 pin via an adaptor.
13 pin pinout:
It depends which model you have
cheers again.
My adapter works with my alko ATC, Everytime I plug it in the system can be heard and the light goes a solid green
That's very interesting Nick.
Yes, I have twin on the car, and the adapter plugs straight in to the caravans 13 and the ATC activates
