amirmughal
R R Sport Automatic Transmission Failure | |
On a long drive, my 06 model Sport came up with this error, (third time in last 2 months).
Limited Gears Available
Special Programs OFF
F code on dash
I stopped the car, switched off and started back up again, to get me home, some 300 kms away. I noticed the third gear was dragging and not changing in low rpm. It would change at usual 4200 rpm and gears 4 and 5 are fine.
I did a diagnostics to get following erros.
Inccorrect Gear Ratio
Invalid data received from Engine Control Module
Incorrect Data received from Transmission control module
Ride Height error
Once all erros were cleared, the car started to drive again as it should and gear 3 changed at low rpm.
I would like to cure this once and for all, and apreciate advise on what to do.
Is a gearbox oil / filter change advisable?
Thanks
Amir Amir Mughal
RRS 2006, Zambezi Silver, HSE, FACE LIFT 2012
Sun Dec 30 2012 11:19pm |
