Home > Faults & Fixes > Water drip from interior light panel ?? |
Montythegod Member Since: 31 Aug 2012 Location: Medway, kent Posts: 268 |
After some hard conerning and braking, i have noticed a drip of water from the front of the interior light panel above the centre console !
Sun Dec 30 2012 3:27pm |
LMAO !! hey no probs... Why?.. Because i can....
Sun Dec 30 2012 5:58pm |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 |
Monty - this screams sunroof drainage issue, but it could also be water getting in around the GPS aerial? Is it loose? Has it been sprayed with a pressure washer?
Sun Dec 30 2012 7:14pm |
Ive had another quick look and cannot see any blockages in the sunroof by pouring water into the channels..
Wed Jan 02 2013 7:20pm |
Sounds very much like sunroof drain pipes...the best bet is not to pour water down them, its likely to not work - you need to fire some compressed air down up (probably) or down them
Wed Jan 02 2013 7:56pm |
Wilmtake a look once the rain has stopped here tomorrow and report back! Why?.. Because i can....
Wed Jan 02 2013 8:04pm |
Cupra Member Since: 20 Oct 2012 Location: Kent Posts: 81 |
mine did the same Monty, fired up the Audi compressor and blew the pipes through. Since then ive had no more leaks |
Wed Jan 02 2013 9:59pm |
Rather than a compressor, some of that 'netting curtain' wire is excellent for gently pushing down the drain tubes to clear them out. Bodsys Brake Bible
Wed Jan 02 2013 11:52pm |
Don't forget there are drain tubes that go to the rear of the car also. Be careful pushing wire or using high pressure as there is a 90° elbow in the tubes in the A pillars which could cause leaks in other places if its pulled off.
Thu Jan 03 2013 12:33am |
Had the front grilles out and only found a very small amount of muck, water flow was same before and after.
Thu Jan 03 2013 5:57pm |
Have a read of the whole thread I linked above...tells you everything you need to know.
Thu Jan 03 2013 6:58pm |
