![]() | Home > Maintenance & Modifications > Do you know what fuse is for the rearlicence light on a 2006 |
Did you use a normal bulb or LED ?
Fatandre Member Since: 05 Oct 2009 Location: Reykjavík Posts: 402 ![]() ![]() ![]() |
Where the tow bar you mean where you lower the spare tire under the carpet? 91 BMW 850CSI |
Sorry, don't have a 2006, but the handbook says under the cover, ie the bit you lift up to access the tools etc, inside the boot. ON THE WAY: BMW F21 M140i
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
Yep, should be on the left hand side IIRC |
Just looked in the trunk and no fuse box.
Silly question, but do you have the owners manual |
Superb. I dont have it so this will be a big help 91 BMW 850CSI |
It should be on the left hand side when you lift the tool compartment in the boot...
No such fuse box in the trunk.
Fuses will then either by in the glovebox (behind the drop down) or under the bonnet.
Might be different in a US spec TDV8, not sure. I've had a look in the Disco3 haynes and it only mentions the towbar fuse box for the numberplate light but that is for the TDV6.
according to the online manuals there is supposed to be a box in the trunk and this is my trunk
http://www.rrsport.co.uk/forum/post244521.html#244521 Malaysia Boleh!
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
Posted on DISCO3 as well but I have looked in the NAS 06MY handbook and it is Fuse 4 behind the glovebox.
