Home > Technical > Loud Grinding/Vibraiting noise |
B.Safe Member Since: 28 Jun 2012 Location: London Posts: 113 |
Me for years
Thu Nov 29 2012 9:31pm |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
I think mine does that - more grumbling than grinding. I never really gave it a second thought. It's not especially intrusive or worrisome... not until I read this post, anyway...
Fri Nov 30 2012 9:48am |
Imported a Chevy Camaro SS donkeys years ago - that had the same issue - no fluid in gearbox.
Fri Nov 30 2012 6:52pm |
This is the only reason I am sorry I ever bought an RRS. Every time I get in the car and then while driving this noise makes me checking if the windows are fully closed which they are
Fri Nov 30 2012 11:20pm |
Mine too. Low frequency vibration (or rumble) at 20-40 ish. Not loud though. Not wheel bearings, not front diff (replaced it to cure a worse noise on lift off at high speed - successful) not tyres - just replaced. Not wheels - just had refurb/run out and flat spots checked. Not alignment - checked and OK. Unlikely rear diff - changed oil but the old stuff was not black and not too many iron filings on drain plug. Remaining suspects are transfer case and gearbox? There is a known issue with clanking chain on transfer case but it is not that. 2008 MY Java Black TDV8 HSE
Sat Dec 01 2012 3:02pm |
defender_uk Member Since: 08 Aug 2006 Location: North Yorkshire, Pickering Posts: 169 |
my 2011 tdv6 does the same.....only done 9000 miles.
Sat Dec 01 2012 5:21pm |
Interesting - we need to get the cause of this.
Sat Dec 15 2012 5:30pm |
The noisy I hear (very annoying) gives me the impression that the front passenger window is not fully closed.
Sat Dec 15 2012 9:59pm |
solved
Sun Jan 27 2013 5:48pm |
