Home > Wheels & Tyres > Wear? |
FF1078 Member Since: 25 May 2011 Location: East Yorkshire Posts: 69 |
I had to change fronts on my last TDV8 and the rears never seemed to wear at all 10 TDV8 Santorini |
Thu Dec 13 2012 11:08am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
Contis have been well documented on here having edge wear/feathering - 10k miles on mine
Thu Dec 13 2012 11:24am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
The Conti shoulder wear is a feature of the tyre - the shoulder blocks aren't as deep (4mm instead of 8mm I think) as the rest so the tread looks more worn than it is. This is the official line from LR/Conti. 2012 SDV6 - it's missing a couple of cylinders
Thu Dec 13 2012 11:32am |
Hence now running pirelli and will never buy contis again Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Thu Dec 13 2012 11:42am |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Same, always fronts that need to be replaced long before rears. I had contis for years and did @ 5 k miles before they were "illegal" on edges according to local traffic plod. Scorpions last 15-20k longer. Last set did 25k and wore evenly. Was a bit of a surprise when I went to get them replaced and found previous tyre bloke had fitted 295 and not 275. Mind you the 295 were three hundred quid cheaper than set of 275. Work that out??? |
Thu Dec 13 2012 1:59pm |
Interesting. Unless you were showing cord on the shoulders or the outer worn band extended in to the central 75% band of the tyre then it sounds like plod might have been talking rubbish. There is no requirement for tread blocks on the shoulders - the shoulder can be slick so long as the central 75% of the tread is 1.6mm deep. For a 275 wide tyre, that means you can have a smooth shoulder that extends in from the edge by 34mm on each side. I'd have been tempted to argue the toss but that's likely to have them check the car over for an hour in order to find things that are dodgy. Probably invites a breath test too for good measure. As for price variations, I guess it comes down to popularity; if the tyre size is popular and thus they make lots of them then the price is probably going to be lower. Alternatively the tyre guy had a set of tyres he wanted get rid of so discounted them. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Dec 13 2012 3:34pm |
Long story short, the traffic plod was peak down over eyes, so knew it was going to be poo. Had claimed I was doing and average of 95 for 13 miles he followed me on A303. Problem being I clocked him in plain Skoda as I passed him three miles before he stopped me and car was set and sat at 80 until I hit brake pedal to pull in when blues came on.
Thu Dec 13 2012 3:43pm |
Ah sounds like he was just making an excuse to waste your time before giving you the ticket. Sort "you're in a hurry so I'll mess you about just because I can".
Sat Dec 22 2012 8:14pm |
