Home > General > Drivers seat ,Creaking |
HPB Member Since: 01 Dec 2012 Location: Gauteng Posts: 11 |
Got squeeky sound on mine as well. Thinking of buying new base RRS supercharged MY2012 |
Sun Dec 09 2012 6:32pm |
rm0rgan Member Since: 04 Jun 2011 Location: Ross on Wye Posts: 42 |
Yup - mine started doing it after the dealer tried to stop it rocking....I think I preferred it rocking than creaking Wife's Car: BLACK RRS TDV8 HSE with all the bits
Sun Dec 09 2012 11:21pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
There is a modified seat base available. Mine creaked, was changed under warrentee and got rocking chair instead. After several attempts to rectify this, they fitted a beta version seat base that solved all the problems. That was few years ago so presume that LR then manufactured the beta base as regular replacement 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sun Dec 09 2012 11:45pm |
ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298 |
the squeaking on mine had to do with the widest part of the seat base rubbing against the inter seat console...Im not a giant so have my seat forward..moving seat back and polishing leather and the console helps |
Mon Dec 10 2012 12:33pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Is that why the later models have a suede (imitation ?) material on the parts that touch the console I wonder ON THE WAY: BMW F21 M140i
Mon Dec 10 2012 12:43pm |
monkey417 Member Since: 10 Dec 2012 Location: Hampshire Posts: 2 |
Hi Guys, had this problem myself..hell of a squeek coming from my drivers seat, strangely only when i turned left! was driving me nuts after a little investigation found that the torx bolts securing the seat frame to the floor had come a little loose..litle tweak and problem solved..
Mon Dec 10 2012 1:40pm |
jakeob Member Since: 21 Nov 2012 Location: cheshire Posts: 64 |
I might try riniging LR at Knutsord to sound them out, i only have a non dealer warrenty so i cant imagine it covering this kind of problem,,
Mon Dec 10 2012 6:49pm |
No non-warranty won't cover it.. Had the seat base and frame replaced earlier this year! Won't tell you how much!!
Mon Dec 10 2012 7:04pm |
