Home > Maintenance & Modifications > llams suspension mod
taff
Wales 2006 Range Rover Sport 4.4 V8 SE Zermatt Silver
Just found this on the internet tonight. Found previous threads about it, sounds a very good idea as I currently have to use Johnson Rods when going off road to get the extra height.
Would just like to know are they available anywhere except Australia???
Cheers Taff. Range Rover Vogue Classic 3.9 V8 1992
101 Forward Control GS 1977
Range Rover Sport SE 4.4 V8 2006
Post #365925 Sat Dec 08 2012 9:56pm
garrycol
Australia
If you go over to the Disco3 http://www.disco3.co.uk/forum/ and send a PM to GraemeS as he is the designer and builder of the LLAMS system - I am sure he can send you one if there are no local suppliers - installing the main unit is no major issue as it just plugs into the loom under the drivers dash.
The main issue for the RRS is where to locate the controller as there are less spots than a D3. I put mine on the steering column - not ideal but you get used to it and can adjust height by feel.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #365957 Sun Dec 09 2012 2:09am
flydive
Graeme ships everywhere, no problems.
As Garrycol said is a very easy and quick install, main job is removing the trim panels to access the module.
Here is where is installed the switch, easy to reach and to see.
This is the MK1 temporary installation, now I've cleaned it up a bit, with the MK2 temp installation Wink '08 RRS TDV8
Post #365965 Sun Dec 09 2012 8:44am
taff
Thanks for the photos, will get in touch with him and see if he can send one one, like the place where you hve fitted it, i have noticed that blank also.
Cheers, Taff. Range Rover Vogue Classic 3.9 V8 1992
Post #365967 Sun Dec 09 2012 9:00am
garrycol
Australia
Not as easy as it looks though Crying or Very sad 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #365980 Sun Dec 09 2012 10:08am
taff
Had email back from him, only $23 aus postage to uk! Going to see my local dealer workshop manager about fitting, dont fancy pulling interior apart will probably break something.
Thanks for yor help. Taff. Range Rover Vogue Classic 3.9 V8 1992
Post #366001 Sun Dec 09 2012 12:59pm
flydive
Should take no more than 45 min to install and calibrate. '08 RRS TDV8
Post #366006 Sun Dec 09 2012 1:32pm
