![]() | Home > Technical > "Suspension will raise once system cooled" issue |
Did they change the relay at the same time? If its constantly running, it will get hot and fail eventually. Relay is well known to stick which is why they say it should be changed each time pump is changed. |
Older cars will flash up this message if you go from access to off road 4 or 5 times within 2 or 3 minutes.
cezman04 Member Since: 01 Nov 2012 Location: london Posts: 4 ![]() ![]() |
thanks for the info well the car is in the delears again today so have to see what they tell me il ask about the relay.
