Home > Technical > Egr Valve
madmackie
United Kingdom 2005 Range Rover Sport TDV6 HSE Bonatti Grey
Egr Valve
Hi all can anyone explain what symtoms you get with a sticking egr valve on a 55 plate sport diesel i assume there is only one and is it possible to lubricate them /it if so how do i find it/them thanks in advance pete
also where is the battery situated is it under the cover on the right under the bonnet cheers
Post #365122 Sat Dec 01 2012 10:32pm
Disco_Mikey
Lack of power, poor throttle response etc
As yours is a 55 plate, they can be blanked. Pair of blanking plates can be bought off Ebay for £10 Thumbs Up
There are 2 valves, one on each side. Normally they fail without warning.
The battery is located under the rear right hand plastic cover, if you stand at the front of the car
Post #365135 Sun Dec 02 2012 8:14am
madmackie
Thanks Mikey for your help my rrs is fine i just keep reading and hearing about egr valves and im new to rrs so just getting a little knowledge probably wont sink in but worth a try cheers pete
Post #365138 Sun Dec 02 2012 8:28am
Disco_Mikey
Personally, I would have them blanked off, regardless if there was an issue or not.
If the valve does fail, in true LR fashion, it will fail at the most inopportune moments!
If they are blanked, and a valve does fail, you will never know about it Thumbs Up
Post #365143 Sun Dec 02 2012 9:15am
madmackie
Hi mikey a daft question will blanking them off interfere with mot can you tell if it has already been done and lastly is it easy enough to do is there a how to on here thanks pete
Post #365144 Sun Dec 02 2012 9:20am
Disco_Mikey
It wont interfere with the MOT as yet. It is still not a failable item.
However, if the valves are blanked, it is quite difficult to see if it has been done, due to lack of access/visibilty down the side of the engine.
There is a more expensive EGR removal kit available, but this kit does away with the pipework all together. IF it then does become a failable item, these people may then have to buy themselves all the appropriate pipework to make it look like they have not been tampered with Whistle
They are easy enough to do. Last set I done in just over 30 mins
There is a how to floating around someplace, over on D3 IIRC
Post #365147 Sun Dec 02 2012 9:46am
madmackie
So it's better to blank than remove so if it does become mot able you should be ok what is d3 iirc please
Post #365160 Sun Dec 02 2012 11:35am
Disco_Mikey
Disco3.co.uk + If I Remember Correctly
Post #365174 Sun Dec 02 2012 4:49pm
madmackie
Hi mikey if you or anyone could point me in the right direction of a how to for tblanking he egr valves on a rrs 55 plate i would be grateful im about to have the cambelt done so i might do it myself with the help of a mate and do the egr's while im at it just so i know they are blanked off thanks in advance
Post #365182 Sun Dec 02 2012 7:11pm
Disco_Mikey
How To - Blank EGR's
Post #365184 Sun Dec 02 2012 7:50pm
madmackie
Thanks mikey looks tricky anyone near to wigan who does this job let me know cheers pete
Post #365186 Sun Dec 02 2012 8:07pm
Boost
United Kingdom 2007 Range Rover Sport TDV6 SE Zermatt Silver
I've been thinking of blanking mine off, is it possible on an 07, I've read somewhere that it might not be, how can I tell for sure? Is it a chassis number thing?
Post #365317 Mon Dec 03 2012 8:08pm
Disco_Mikey
The 10th digit of the chassis number, corresponds to the model year of the car.
For example, SALLSAA137A****** would be an 07MY. It changes at 2010MY to letters, instead of numbers Thumbs Up
Post #365343 Tue Dec 04 2012 6:56am
Boost
Blonde question - what does the MY stand for?
My chassis number is SALLSAA137A1***** does this mean it can be blanked with the kit?
Post #365347 Tue Dec 04 2012 7:30am
Model Year Thumbs Up ie MY 10, 12 13 etc, its just a term we use just like other car forums.
Post #365348 Tue Dec 04 2012 7:53am
