Home > General > New Steering Rack |
Thats shocking my dealer took around 4 attempts to get mine straight but i have noticed that its slightly out again only by about a few mm's down on the right i havn't hit any potholes or any kerbs either my front brakes have started squeaking too, but only when i come to a near stop. Hope the new rack solves your problems. |
Tue Nov 20 2012 9:42pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Although good that they are replacing the parts, I can't help but feel that they are just unskilled at the alignment
Tue Nov 20 2012 10:04pm |
Cheney Jawa Member Since: 25 May 2012 Location: Birmingham Posts: 89 |
2 weeks, still at the dealers , still no joy
Fri Nov 30 2012 1:08pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Be careful or they will tell you that you drive it too hard. Been there had that. My dealers had numerous goes at getting steering right, even blowing tyres up to odd pressures. Eventually I read the LR workshop instructions and put it on our bear system will full tank of fuel. Does give option to add 100kgs to drivers and rear offside footwells. After this the car drove straight, didn't pull and steering wheel spot on and stopped the car eating tyres every 4000 miles.
Fri Nov 30 2012 1:23pm |
Had my motor in today for its squeaky front brakes and found out that there is a TB (Technical Bulletin) for the Disco & sport, Action, replace front brake pads. So if you have a 2012/13 disco or sport (Diesel model) and your brakes are squeaky then it might be worth getting intouch with your dealer. Had a play in an Evogue while mine was in for repair, not my cup of tea but if you want a car instead of a 4x4 then an Evogue might just be the motor for you, drives like a car, handles like a car, and next to no bigger than an average size car |
Sat Dec 01 2012 7:45pm |
