![]() | Home > Wheels & Tyres > Spare Tyre Wire - not winding properly |
Well if you look on here you will see the price for the replacement stuff following thefts £200 ISTR
Franko Member Since: 21 Aug 2012 Location: Glasgow Posts: 13 ![]() ![]() ![]() |
No its out of warranty unfortunately. It was winding down a little but now it is just spinning ![]() |
Think you will find its a new one then. I would take it off and see if it can be repaired, but thats how my brain works
i'll give it a shot. Try n take it off myself and see how it goes. 6bolts u say? are they visible from underneath the car. To be honest ive not even looked as it was dark when i picked the car up. Range Rover Sport Supercharged 2006 plate |
Yep 6(might be |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Well known problem. It's a new winch assembly in my experience. FF 4.4 V8 Soooo looking forward to this bad boy
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
Total waste of time trying to repair, its a sealed unit, i prised it open but to no avil.
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Had this problem myself - nearly gave up but a Rac friend came to my rescue - remove the sealed unit from the car - place it in a vice - slowly but with force pull the cable out of unit - get someone else to hold a ratchet / spanner on the bolt that lowers - highers the cable on the unit itself - this is to add resistance. I've now had to do this process twice both times with success. It's a known fault but doesn't have to mean replacing.Good luck. |
