Home > In Car Electronics > Battery 'trickle charger'.
petsar68
New Zealand 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Hi - i am soon to head off overseas for 6 weeks. The car will be parked up and left until i return. I am wondering if as well as lowering the suspension it might be beneficial to connect the battery to a charger allowing it to be maintained.
Having checked there are a number of options open to me but i am curious whether or not anyone has any experience in using these chargers and if so what are your thoughts.
If i do purchase one then does it have to have a particular output ?
The one i have seen is as follows - INPUT 240V, 50Hz, 28W
OUTPUT 1600mA (2.5A RMS*) at 12.0V
CHARGE CONTROL: (Cut out: 14.2V) (Cut in: 13.4V) (Start: 5.0V)
Thanks. RRS TDV6 HSE
Discovery 3 TDV6 HSE - Sold
Discovery 2 V8 ES - Sold
Post #364837 Thu Nov 29 2012 12:49am
Stefan.lajszczuk
United Kingdom 2006 Range Rover Sport SDV6 SE Rimini Red
I've got a ctek xs 3600 and it's worked wonders for me on many vehicles. I've had a P38 Range Rover which barely lasted a week without going flat, a BMW 5 series which I didn't use for over a month and both vehicles started first time after being connected to the charger.
It's also helped me get a car started when the battery has been too flat to crank within 30mins of leaving it connected and helped revive a couple of old batteries which he thought were past their best.
I believe this model has been superseded now but I won't buy anything other than ctek now, after trying other cheaper brands!
Post #364839 Thu Nov 29 2012 4:04am
TST717
Scotland
I can recommend CTEK also, I have used these on all my cars and they are easy to use and perform well.
I left my RRS outside last time I went away for 6 weeks and it was flat when I returned. The CTEK had it charged within a day to normal , then run the car afterwards with as little load on , light off etc to allow the alternator to fully charge the battery in normal way. no lasting effect.
I have installed the permanent wiring leads to the battery so it's just a plug and leave affair.
Cheers, TDV8 HSE....Gone but not forgotten ....class act
Cayenne S diesel.....850n/m....385bhp....the danglies ...
Post #364843 Thu Nov 29 2012 8:15am
Cupra
i use a Cteck. had mine on the GTR as you could only leave it a few days before it died. have one on my Classic car thats being stored for winter
Post #364876 Thu Nov 29 2012 12:32pm
mjbrr
United Kingdom 2009 Range Rover Sport TDV8 HSE Santorini Black
+1 for the ctek.
Had one plugged in the cigar lighter in my porsche when I was away.
Always tip top when I came home. 2009 3.6 TDV8 HSE Santorini Black
Post #364878 Thu Nov 29 2012 12:47pm
petsar68
Thanks guys - ctek it is then. Now to see if i can source one here in NZ ! RRS TDV6 HSE
Post #364918 Thu Nov 29 2012 5:52pm
