Home > Maintenance & Modifications > IN CAR ENTERTAINMENT!
Harry HST
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Java Black
Hi
I've managed to get my HSE facelifted to the Autobiog and also had a colour change to white!!
As we all know the HK/Logic 7 sound isn't really all that good especially the standard subwoofer!!
I have managed to Wire up and added my own Amplifier 2 x 12'' Pioneer Subwoofers to give it that extra kick!
All took me no longer than 45 minutes!
Pictures will be updated over the weekend subject to the weather Smile
Post #364128 Thu Nov 22 2012 9:52pm
#76
Nice one buddy!, looking forward to seeing some pics of your install.
I am thinking about adding a sub, but will wait and see how you have done yours first.
Thumbs Up TDV8
Custom map & K&N
Straight through Exhaust
...Awesome!.
Post #364182 Fri Nov 23 2012 8:50am
URX
Scotland
intersting as I havea spare Alpine 1kw bridgeable amp sitting spare Shocked should up the game a little if its straightforward to include
Post #364214 Fri Nov 23 2012 1:19pm
Harry HST
I will aim to upload pics for sure this weekend.
It is very straight forward without a doubt, I have seen many threads on the internet and some have taken the person hours and hours and even then the job looks messy.
There is nothing to be pulled apart and stripped apart from the norm to feed the wires which I'll also show you so you can visualise this.
Post #364216 Fri Nov 23 2012 1:22pm
#76
Nice one Harry, await your pics! Thumbs Up TDV8
Custom map & K&N
...Awesome!.
Post #364266 Fri Nov 23 2012 10:17pm
karan538
2008 Range Rover Sport TDV6 HSE Santorini Black
it would really be great if you made a quick and simple installation guide on it or answered just some of these questions because I want to install a Sub in my range, ive already done one in my mercedes e class but it was partly easy because the battery was at the back and used a high to low with the factory sub at the back..
1) How did you manage to run the power cable from front to back? How easy was it to accses firewall?
2) Where did you get the rca output to the amp from? Did you use high to low from the sub at the back or anything else.
Thanks alot
Post #364286 Sat Nov 24 2012 2:46am
#76
Where's the pics buddy!?.... Whistle TDV8
Custom map & K&N
...Awesome!.
Post #364567 Mon Nov 26 2012 7:36pm
Harry HST
Terrential rain down here over the weekend so unfortunately no pics the weekends the only time I get!
Post #364593 Mon Nov 26 2012 10:32pm
Harry HST
Quick installation guide:
1. Underneath the Driver side footwell remove the 2 screws and pull the cover down ( This is the cover with the footwell light in it )
You will see a rubber bung, drill a hole through this enabling you to get a 4 Gauge Power cable through.
2. Run the Power cable along the firewall and feed it the same way as the loom is going so its not visual, once done use your power cap and fee the wire into the cover where your battery is and connect.
3. With the wire going through under the footwell, removal the plastic trims on the sills for front and rear and run the cable through to the back and then under the rear seats.
4. Use a Hi to Low from the green/green & white wires which run directly to the rear sub to get your rca outputs.
5. Use the rear cigarette lighter power as a remote wire.
6. On the inner side of your rear quote there are very easy access points to gain a ground.
7. Run your wires neatly and connect to your Amplifer.
8. This should take you no more tahn 30 - 45 minutes.
I will upload pics once the rain calms down and you will be able to see how proffesional this all looks!
Good Luck! Thumbs Up
Post #364595 Mon Nov 26 2012 10:40pm
#76
Nice write up mate!...
Any pics of said install this w/end buddy?
Thumbs Up TDV8
Custom map & K&N
...Awesome!.
Post #365074 Sat Dec 01 2012 5:00pm
karan538
i have been trying for ages to install my sub but cannot seem to find a way to get my power cable through. i have a couple more questions if u guys could please answer
1) harry, is your car the uk right hand side driver version?
2) the engine bay is pretty tight, how easy was it to run the wire through from the drivers side? apart from the footwell cover did you remove anything else.
3) where did you find the rca output for the sub, can you tell me the exact detailed location.
i really wanna do this install myself, tempted to get it done professionally but dont want to waste extra money
i just need a detailed explanation off exactly where to run the power wire, as i cant access the firewall and the rca output for the sub. i already have a low to high.
thanks,
Post #365584 Thu Dec 06 2012 12:14am
Harry HST
Hi Karan
The car is a right UK hand drive.
As detailed in my previous post you have to run the wire against the firewall or you can channel it your own way as close to the firewall.
The subwoofer wires are green/green white in the rear quarter of your car, you have to remove the inside covers to access this.
If you are struggling to do this then I wouldn't really reccommend you doing it yourself as the last thing I would want you to do is to trigger something else off.
Either visit a professional who may charge you around £200 for the install or if your local I can do this for £125.00.
Regards
Post #365753 Fri Dec 07 2012 12:42pm
Harry HST
Pictures will be uploaded when I get a chance guys sorry about the time taken I just haven't the time at present.
I will take pictures of the completed as I dont want to start taking trims firewall covers apart then putting them back again.
Post #365754 Fri Dec 07 2012 12:45pm
karan538
harry i have my car opened up right now. i opened the bottom cover with the light and there are two rubber gromets, left amd right. which one shall i drill into? they both look like they have somthing to do with the pedals though
Post #365755 Fri Dec 07 2012 12:47pm
karan538
if i look into the other side in the engine i can see a bunch of electrical wires going in but u cant see them on the other side
Post #365758 Fri Dec 07 2012 12:58pm
