![]() | Home > Technical > help i need to remove a engine out off a range rover sport |
jvautos Member Since: 21 Nov 2012 Location: hampshire Posts: 28 ![]() ![]() |
body is off just got home nakerd i still carnt post piks can i do it from my mob ? |
[/img] |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4424 ![]() ![]() ![]() |
HOw long did it take you in the end? |
not to long it was dropped off at 4 and i left work at 10 oclock but had some trouble with a few body mounting bolts being seized gowing to change the engine this morning and drop it back on
I had my first RRS body off at 19... And replaced a turbo (TDV8) and refitted the body in under 12 hours... |
range rover sport auro how do i remove gear box if the engine is locked solid ? and i carnt tern it to get to the torque converter bolts help asap cheerrs |
