![]() | Home > Maintenance & Modifications > Airbag warning light! |
stevemfr Site Sponsor Member Since: 21 Aug 2011 Location: Strasbourg Posts: 55 ![]() ![]() |
The connector for the SRS system should be yellow. You may have a fault logged that will need to be removed with an appropriate LR diagnostic tool. If the connector was not attached properly, I'd go directly to a dealer, let them find the connector and then go back to the upholstery shop with the bill. |
The Cakes Member Since: 19 Nov 2012 Location: Chesterfield Posts: 2 ![]() ![]() ![]() |
Thanks for that, I've got a couple of other things that need sorting so I'll get it booked in. |
