Home > Maintenance & Modifications > Brembo Front Disc sizes
jaguar1
Saudi Arabia 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Hi all,
I am about to replace the front discs on my 57 plate TDV8 RRS and hoping to save a few pennies by replacing them myself. Anyone done this for the front Brembo's? and how easy is it?
After looking through various aftermarket sites (including ebay) I have found discs for RRS/ Range Rover for 2 different sizes of disc. Both are 5-stud fitment but one is for 345mm diameter and one is for 360mm diameter. If I was at home I could simply measure the old ones but I work abroad so obviously I cannot. If I asked the wife to measure them, she'd probably measure the tyre width or something....My question is are there actually different sized Brembo discs fitted to RRS 3.6 TDV8's and if so can I tell by the VIN?
Maybe the 345mm is for the Range Rover and the360mm for the sport?
Thanks in advance, John.
Post #363673 Mon Nov 19 2012 1:03pm
360mm front discs is what you require for the 3.6 TDV8 Sport. Thumbs Up
Post #363676 Mon Nov 19 2012 1:29pm
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
Hi, changing them is no problem. Hardest thing would be cracking the bolts otherwise they re straight forward job.
Post #363677 Mon Nov 19 2012 1:50pm
Bodsy
Site Sponsor
my brake bible may help you. If you take plenty of pics, I'd be happy to update it to include the Brembo's for future use. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #363680 Mon Nov 19 2012 2:13pm
jaguar1
Cheers for the info guys, it's much appreciated. I'll let you know how it goes.
John.
Post #363744 Tue Nov 20 2012 12:33am
