![]() | Home > My Range Rover Sport > Satnav voice - question |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 ![]() ![]() |
Have a look at
Bobs_buggy Member Since: 30 Apr 2006 Location: Pump No.3, usually! Posts: 213 ![]() ![]() ![]() |
Thanks Derek,
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Unless you happen to be on a telephone call (on cars equipped with PTI), in which case the caller voice comes through the front speaker and the Nav voice is temporarily "relocated" to the rear speaker(s), haven't identified which one(s). Also, it does not shut up automatically while you are talking on the phone, which can be annoying for both you and the caller, so you need to quickly lower the volume manually while Betsy talks. I hope Land Rover fixes this one in the future, at the very least they should give us an option - under Nav Setup - to mute voice guidance automatically while on a PTI call, like the radio does already. |
Boaz Member Since: 13 Apr 2006 Location: Los Angeles Posts: 26 ![]() ![]() ![]() |
Agree with Umberto. SatNav voice keeps talking while on a bluetooth call. I've taken to just hitting mute manually on the SatNav when a call comes in. But they should fix that or offer an upgrade. It can't be that hard. 2006 Bonatti Grey HSE; Ebony Lux Package; Bluetooth; Sat Radio; Rails & Crossbars; Mudflaps; Nitto TerraG's; Matt. 6:33 |
