![]() | Home > Maintenance & Modifications > Problem with key. Sometimes it doe snot ope nthe door |
Yes there is a battery in the remote and it does need to be changed...well on the new ones that dont have a key Mike
Fatandre Member Since: 05 Oct 2009 Location: Reykjavík Posts: 402 ![]() ![]() ![]() |
Its a 2006 RRS.
mark hamster Member Since: 26 Nov 2011 Location: nottingham Posts: 116 ![]() ![]() ![]() |
i thought they charged up when in the ignition |
Montythegod Member Since: 31 Aug 2012 Location: Medway, kent Posts: 268 ![]() ![]() ![]() |
They charge using an inductance loop... Wirelessly when in the ignition, the battery is a small panasonic nicad that fails after a period of time and can be changed by breaking the key open and desoldering the old battery and replacing with a new one.
So if I press the third one and the trunk opens it means what?
It means the 3rd button has been programed to open the boot |
RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176 ![]() ![]() ![]() |
It also means that the battery on the key fob is working suggesting it may be your door actuator |
Is it a common fault? 91 BMW 850CSI |
not uncommon on the older cars |
OK. So is there only one actuator or in every door?
Seems a fairly common problem with the door locks. See this thread and my post for a detailed link for how to do it.
All my doors unlock. The problem is that when it stands overnight, sometimes it is hard to get it to open in the morning.
If the third button operates the boot and the first button doesnt unlock then the battery is probably ok and the issue is a worn button or door mechanism sticking..
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
The Definitive 'how to' thread in the technical section has a link that explains how to change the rechargeable battery.
