![]() | Home > Technical > Heating not working |
Sorry to hear about your problems. Try not to drive too far until this is fixed as overheating can badly damage the engine. No heating implies no coolant in the heater matrix caused by a leak or an airlock OR there is coolant in it but it's not circulating. Check the coolant level and if it is OK check strength of antifreeze just in case it is freezing (unlikely - but we did just have our first really cold night). Check the radiator for blockage by feeling it top and bottom and check the core for cold spots but be very careful - engine off and fan disconnected. If water is circulating through radiator it should be hot everywhere but hotter at the top. Check the drivebelt that drives the waterpump has sufficient tension. On some cars (not sure about RRS) the waterpump has a plastic impellor that detaches from the metal driveshaft so everything looks OK but in fact the pump isn't doing any pumping. Severe corrosion of the impellor due to old ineffective antifreeze is another possibility. Thermostats can fail to open and cause overheating by not allowing coolant to circulate but usually there would still be heat from the heater. A nasty possibility is a head gasket failure causing an airlock and a garage can test for this by using a 'sniffer' to detect combustion gases in the cooling system. Be warned tho' my friend (who lives in France) was convinced his BMW 520 had this problem causing intermittent overheating like yours but after an expensive head gasket change it turned out to be a blocked radiator core (just like I suggested when he first 'phoned me |
Tiny Timmy Member Since: 20 May 2011 Location: Bucks Posts: 233 ![]() ![]() ![]() |
Thanks thats a lot to take in |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
Yes please keep us updated. It's not uncommon to find a leak in the rad.
Just an update Having checked the rad properly Its Leaking quite badly!! So I have changed it and everything is back to normal, so Far!!!!??? Thanks for all your help.......TT |
Great stuff! Thanks for the update |
Good news. Just out of interest - which antifreeze did you re-fill with? 2008 MY Java Black TDV8 HSE
