Home > Technical > Weird Coolant Issue |
abcsworld Member Since: 08 Jan 2012 Location: France and UK Posts: 12 |
is your engine oil becoming like mayonaise...? If looks like it it means water gores into the oil. Get engine check asap. |
Sat Jun 02 2012 9:12pm |
shedden Member Since: 31 May 2012 Location: Kuala Lumpur Posts: 2 |
The workshop has checked the oil and they said that everything is ok, that's why they are puzzled right now |
Mon Jun 04 2012 4:16am |
maddie Member Since: 10 Jan 2011 Location: HERTFORDSHIRE Posts: 6 |
hi sound like the same problem on my v8 sports and i have change the expansion tank still low coolant come on i think theres air in the system but not having much luck with bleed it fom the expansion tank point dont kown if theres other bleed point. JEFF GALE |
Fri Nov 09 2012 6:29pm |
Harryrrs Member Since: 20 Feb 2020 Location: Luton Posts: 7 |
Did you sort this problem as I have the same problem ? |
Thu Feb 20 2020 11:02pm |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 535 |
It sounds like a head gasket issue to me....the water system is being pressurised by combustion gases?? |
Thu Feb 20 2020 11:53pm |
I have similar but block test is negative every time and go oil to coolant contamination |
Fri Feb 21 2020 7:38am |
I’ve just had the same symptoms but on a different type engine....which turned out to be a slight leak on the head gasket...was loosing a tiny amount of coolant which was actually being forced out of the expansion tank breather...but would only do it when it was driving at higher revs...
Fri Feb 21 2020 8:35am |
If I open coolant cap when engine running and increase revs the coolant level drops right down , and then comes straight back up after releasing ? Was yours doing this ? Also I have constant pressure in coolant tank |
Fri Feb 21 2020 9:11am |
Just take it back to them and tell them its not fixed yet. |
Fri Feb 21 2020 11:34am |
He has no idea anymore either |
Fri Feb 21 2020 6:33pm |
